16" wheels on SS
16" wheels on SS
Hi
Looks like I will have to go with 16" wheels. Reason being I want to use the American Torque Thrust wheel. Found them on Tire Rack.com for $134 each.
http://www.tirerack.com/wheels/Wheel...All&sort=Brand
Thanks
Thanks
If your SS isn't equipped with the Brembo Brakes option, then 16's should fit. Just remember the offset needs to be between 38mm & 42mm, with a 5x110mm bolt pattern.
If you've got Brembo Brakes, you're stuck with 18's, nothing smaller will clear the calipers.
I have the standard front brakes.
Did a little more investigation and found this:
http://www.americanracing.com/wheels/AR105M/AR1054
