20s front 22s rear think it a work
Old Oct 11, 2010 | 02:54 PM
gangster moblie's Avatar
Well that sucks lol.guess niether one wheel work I just thought if I put a bigger wheel on the rear it would just look bigger n add one size bigger tire in the rear just want differnt look .
Old Oct 11, 2010 | 07:21 PM
frank6060's Avatar
I see some guys going with staggered wheels on their FWD vehicles that make them look like ahem..Old Sckool RWD. Maybe 215X20 front 245X20 rear would look cool, keeping the same tire height should avoid trac-control issues.
Old Oct 11, 2010 | 08:59 PM
SHADOW(IN)'s Avatar
With coil spring spacers you need the U shape ones I jacked up the rear removed both wheels removed the upper bolt from the shocks and the rear axle dropped down enough to lift out the stock springs place the spacer ( I used a 1 inch ) in the cup U side up then the spring sits in on top then replace Springs, Shocks & Wheels. Done
JEGS has them for $ 11.99 each. they are not sold in sets
any more ? just ask . )
Old Oct 11, 2010 | 11:49 PM
There are a few here using 20"s, but not sure about 22"s.
Old Oct 12, 2010 | 09:44 PM
SHADOW(IN)'s Avatar
shadow how did you raise your rear end of the hhr thanks for any info you can give me.
I posted a few pics of my HHR with it's new Tatoos the one you can see the lift in the rear. . )
Old Oct 13, 2010 | 01:57 AM
They come stock with the rear TOO high, how high ya need to go ?
Old Oct 13, 2010 | 04:37 AM
SHADOW(IN)'s Avatar
when I got it looked like a old hot rod & besides everyone is lowering . but I like the raised rear look. It was only 1 inch just enough .
Old Oct 13, 2010 | 05:53 AM
LawDog88's Avatar
Gangster Mobile, try 19's as it would not be too big, then just wrap the rear wheels in a little bigger rubber, ex. 215 front and 245 in back.
Old Oct 13, 2010 | 05:54 AM
Ogre999's Avatar
Cool Wow...
Originally Posted by Randy_W
Unless old school is 2005.
Thanks dude ...now I really feel crusty
Old Oct 13, 2010 | 05:58 AM
Ogre999's Avatar
Talking Hmmmm....
well bustin Balls is old school ... Don't let it harsh yer buzz man ...just playin around no one meant any harm my man.
Actually trying to do the same thing but with 16-17 in front 17-18 in back , want a slight angle but subtle smooth kinda thing also want to do a lower offset too on the rear to give a slightly beefeir appearance too...Unfortunately have not done all the math formulations yet as I wont be able to do it untill probably Jan. some time!
