Aluminium rims refinish
Old 02-04-2021, 10:30 AM
I just wanted to share this video, I’m not looking for any view clicking rewards, just wanted to share my experience, refinishing my Colbalt SS rims.
I’m no film studio, I don’t edit (maybe cause I don’t know how)
I’ll post more next time , when I get outside for wet sanding the aluminium alloy rims.
Oldblue is offline
Old 02-04-2021, 10:46 AM
I know that finish was thick, but I would have started with 220 grit, or even 320 grit... Much easier to wet sand from there.
Cleanup from 80 grit can be a nightmare.
Greybeard999 is offline
Old 02-04-2021, 10:54 AM
I know, but with the lock down here, I only had the 80 and 180 grit hook and loop paper. I messed up and said 120 but I saw when I took the paper off the sander, it’s 180 grit.
I have had good experiences going from 80 to 180, then on to 320, then 600.
If they look good then I’ll move up to 800,1,000 and 1,500 wet sand , those I have but they are in my headlights polishing kit, at my friends place, I can’t go get it right now because of our stay at home orders.
I will follow up later on in a couple of weeks.
Thanks for watching and adding your experience
Oldblue is offline
Old 02-04-2021, 12:50 PM
the_shmoo's Avatar
Good job.
the_shmoo is offline
Old 02-04-2021, 01:52 PM
Thanks
Oldblue is offline
Old 02-04-2021, 11:02 PM
Be glad that wasn't chrome you had to sand thru.. They should clean up nice..
sleeper is offline
Old 02-05-2021, 07:05 AM
I was considering that for the winter 17” chrome over plastic rims
These cleaned up fairly well with some elbow grease and pots and pans powdered cleaner
Oldblue is offline
Old 02-05-2021, 08:34 AM
Blue_SS's Avatar
Those look pretty good! I had a guy help me on some rashy ones years back, and he used a stone, like a sharpening stone, on the rough spots. That seemed to work pretty good. I had no rubber on mine, and he powdercoated them after. Not sure they were nice enough to polish up. The powder came out great, though.
Blue_SS is offline
Old 02-05-2021, 09:16 AM
I just might powder coat the alloy rims after these tires are done , I just had the TPMS installed a year ago, so this might be a temporary thing, I do know that Plastidip or that vinyl wrap spray won’t stand up to road grit and grime , so , that eliminates those coatings
Oldblue is offline
Old 02-05-2021, 09:51 AM
Just curious because I don't do this kind of work; is there a reason to not use rouge and a buffer?
donbrew is offline
Quick Reply: Aluminium rims refinish
