Anyone running 225/60r16 tires?
Old Aug 26, 2012 | 06:51 PM
Rotor's Avatar
Want to know if you had any issues with rubbing.
I want to put them on stock 16" steelies.
TIA
Old Aug 26, 2012 | 07:45 PM
prince_bigd's Avatar
You should be able to unless the strut plate causes interference. however these are significantly larger overall diameter than stock. Stock is 215/55/16 or 25.3 overall diameter. The 225/60/16 work out to 26.6 overall diameter. Those is going to place your Speedo off by a decent margin and really lug the transmission down. Gearing would be longer which may make the Tranny need to shift more under load.
Old Aug 26, 2012 | 07:50 PM
swerv0428's Avatar
That would be a tight fit. I just measured mine. I run 215 55 16. My tire is 24.5 to the top. But I only have about 3/4 of an inch to the strut plate. Not sure if that would fit.
Old Aug 27, 2012 | 12:26 AM
"The 225/60/16 work out to 26.6 overall diameter"
I seriously doubt you will clear the strut plates......
I squeezed 26.1" tires on mine, & only have .300" clearance between tire, & strut plate.
My stock tires were 215/50/17 = 25.5" tall..
Old Aug 27, 2012 | 05:14 AM
Yeah I think I recall reading now that 26.2 was the maximum clearance for our hhrs. I wonder why TC wishes to run such a tall tire? Personally my hhr is already geared too tall for my taste 80mph in second lol. I'm coming from my last daily driver running 215/45/17 so I think the stock 16s ride great.
Old Aug 27, 2012 | 05:37 AM
Rotor's Avatar
I am looking a pretty good deal :). I am currently running 205/60r16's so thought the diameter would not be too much different. After checking out that tire dimension calculator, I now see I will be adding almost an inch to the diameter. Have to go check current clearance. Looks like 55's might be best.
Thank you all for your inputs.
SS fan
Tires & Wheels
24
Jan 14, 2013 07:27 PM
5speed4
Tires & Wheels
Sep 16, 2012 08:40 AM
xzombiex66
Jul 29, 2009 04:58 PM
