Changing tire size?
Old May 13, 2014 | 09:37 AM
nycamper's Avatar
Changing tire size?
Has anyone changed the size of the tires you put on? Mine is a 06 HHR LS so stock is 215/55/16 Tires are expensive and don't seem to grip well. Was thinking of putting a narrower tire on. Any advise or suggestions?
Old May 13, 2014 | 10:19 AM
07azhhr's Avatar
Going from a 215/55/16 to a 205/60/16 might open up a few lower cost options. Lower cost options, however, usually come at a performance loss in one fashion or another. Here is the same tire in both sizes. Nothing special about this tire it was just the first one I found in both sizes. Note that the 215 is $1 cheaper.
Tire Details - Discount Tire Direct
Old May 13, 2014 | 10:47 AM
nycamper's Avatar
Guess there isn't a big price change after all. I just need 4 new tires and with 177,000 I just don't want to spend a fortune on them.
Old May 13, 2014 | 11:21 AM
Two identical tires differing only in width of the tread: the narrower one will have less traction than the wider one, in the majority of circumstances.
Old May 14, 2014 | 11:42 AM
Doc brown's Avatar
There are a few low priced options available from Tire Rack, but you'll probably at the same price point after mounting and balancing.
http://www.tirerack.com/tires/TireSe...55&diameter=16
hurst2001
Tires & Wheels
Jan 5, 2015 08:48 PM
windsor837
Tires & Wheels
Jan 13, 2013 10:58 PM
mmont50
Tires & Wheels
20
Sep 13, 2012 11:57 PM
lake
Tires & Wheels
May 22, 2010 11:30 PM
jayhawker
Tires & Wheels
Apr 7, 2008 06:42 PM
