changing tire size
Old Oct 18, 2017 | 09:56 AM
steve2011's Avatar
changing tire size
will a 225/60R16 fit on my 2011 HHR?
Old Oct 18, 2017 | 10:56 AM
yes
Old Oct 18, 2017 | 11:31 AM
Originally Posted by donbrew
yes
Hey Don ???. That size shows to be 26.62 inches tall. Thought max size tires you can fit on the HHR was 26.2.
I would say they won't fit on a HHR because they'll rub on the struts.
Old Oct 18, 2017 | 11:35 AM
Silverfox's Avatar
Michelin 225/60R/16 Defender shows 26.6"
Drop back to 215/60R/16 and your good to go. 26.1"
Silverfox
Old Oct 18, 2017 | 11:36 AM
OOPs, you are right. I was thinking 215/60R16. Damn my lying eyes.
Old Oct 18, 2017 | 01:12 PM
aradmahogany's Avatar
Sorry but why not just go with stock tire size?
Old Oct 18, 2017 | 04:30 PM
215/60's are usually cheaper than 215/55's. With longer warranty.
Old Oct 18, 2017 | 05:14 PM
Silverfox's Avatar
Might get a slightly softer ride with the 60 aspect ratio could be one reason.
I am considering it myself.
Also be aware that quite a few tires made for the HHR are XL. Especially the winter tires.
For a softer ride you would want SL.
Silverfox
Old Oct 18, 2017 | 05:47 PM
225/55r16...
Old Oct 18, 2017 | 06:27 PM
Silverfox's Avatar
225/55r16...
225/55R/16 .... 25.8"
Wider stance and tread width. Should give slightly better handling.
Close enough to not throw the speedo off much if that matters.
Not sure of ride quality change with same Standard aspect ratio as Stock ??
Silverfox
