hhr w/vette rims
Old Mar 24, 2015 | 09:01 AM
Very cool!
Old Jun 7, 2015 | 04:49 PM
harleysshhr's Avatar
Originally Posted by Lethal Tendencies
Thats a C6 wheel. Looks like it has adapters on it
T
It has adapters to correct both offset and bolt pattern. The C4 wheels will work just fine with adapters , but you should use front wheels only because they are only 8 1/2" wide. I'm not saying the 9 1/2" won't work but it's plug and play by using all fronts. I have 10 1/2 on the rear but it's tricky and limits you to one size tire to fit on the rear. Even though the c4 is rear wheel drive it uses front wheel offset around 56mm.
Just for your info, the wheel adapters don't harm the bearings when using a rim that has an equal or greater offset when combined with the thickness of said adapter.
I've done all this, so you could say I might know.
Old Jun 7, 2015 | 11:30 PM
oceangoer's Avatar
harleysshhr,
What which & and manufacturer are the front spacers ??
thanks..
hoganj
Fuel Economy - Hypermiling
19
May 20, 2012 08:31 AM
saxrocks2009
Feb 4, 2011 11:56 PM
87silver
Apr 14, 2010 08:38 PM
Jeff®
Jan 21, 2010 09:13 PM
c2vette
Dec 7, 2008 11:54 PM
