I went with Goodyear Eagle GT's...
Old Jan 28, 2013 | 07:26 PM
VinceP's Avatar
Question I went with Goodyear Eagle GT's...
I decided to go with Eagles GT's as my replacement tires. I had 225/55/16's put on. I had them installed this weekend and so far so good. Thanks for the recommendation.
My question is this for you tire guru's. Since they are a different size from stock what do you think the optimum tire pressure would be for best wear pattern. The max PSI is 51 pounds (from the sidewall) and I am currently running them at 42 PSI. Ride feels good, I just dont want them to wear prematurely.
As always look forward to everyones opinion.
Old Jan 28, 2013 | 07:33 PM
You will have to experiment with it and observe for wear.Are they a w rating I would think 35-36 would be max. Keep an eye out for wear in the middle of the tire with 42 in there.
they aren't so much different size that the door sticker recommendation wouldn't be a good starting point.
Old Jan 28, 2013 | 07:41 PM
VinceP's Avatar
Cool. After they cool down from the drive home I will go reset them. Thanks for the advice.
Old Jan 28, 2013 | 07:48 PM
THE BATMAN's Avatar
Great tire , I ran mine at 35 psi . Super grip for about 22,000 miles . And then there worn out . rotated at 3500 miles,better than the pilot originals but lasted 50,000 miles less than the pilots, But a much more sticky tire .
Old Jan 28, 2013 | 07:51 PM
Mrs. DLVRNIT's Avatar
Glad you like the 225 x 55 x 16's. We run 32lbs front and rear! Not sure what the HHR manual says but I know you'd have alot softer ride with less air .
42lbs just seems a little extreme .....
and I'm sure we'd all like some pics ,
Old Jan 28, 2013 | 07:53 PM
VinceP's Avatar
Glad to hear you liked them. My little Panel is just a daily commuter, non SS 2.2 econo ride. Dont get to hang too many corners or get to drag from red light to red light....lol. So maybe I can coax a little more mileage out of them.
Thank for the input.
Old Jan 28, 2013 | 07:56 PM
skyline26's Avatar
ive heard nothing but good things about those tires! I'd go with those also
THE BATMAN's Avatar
You should get good mileage out of them , I was a bit rough on mine.
Not to mention about $ 500.00 less than the pilots.
Old Jan 28, 2013 | 07:59 PM
VinceP's Avatar
Really starting to sound like I need to drop a few PSI.
I will get some pics taken when I get her washed. I changed the wheels to the 5 spoke steelies and really like the look. Now I need to find some kind of center caps to put on and some black lug nuts.
Old Jan 28, 2013 | 08:01 PM
VinceP's Avatar
Pilots were expensive. I looked. Sears actually had a good deal on the GoodYears. If you purchased on line they were buy 3 get one free. Saved $127.
