Longer Studs for Solstice Wheels
Old May 25, 2013 | 02:29 PM
Putter's Avatar
I have been running a set of Solstice wheels for a couple of years now and never got around to swapping out the stock studs for extended length ones.
Well, after normal wear & tear the time came to change out my hubs (noisy wheel bearings)....so I figured it was the perfect time to add the longer studs while I had it all torn apart.
After reading everything I could find on this forum and comparing part numbers I found a simple way to locate the studs.
**Please excuse me if this is repeat information**
I simply ordered wheels studs for a 2004 Chevy Trailblazer from Rock Auto @ just over a buck each.
Same pitch, shank size, etc.....
Exact same part number as the wheels studs from e-bay listed as "extended length" for the HHR, which sell for over $3 each.
I have installed them already and they are exactly correct. Lugs have plenty new threads to grab onto!!
Just thought this might be helpful for anyone with spacers installed.
Old May 25, 2013 | 02:46 PM
IgottaWoody's Avatar
Just saved me some search time....!
Old Jun 13, 2013 | 12:56 AM
Don Juan's Avatar
These are what I used on mine just touch longer than stock but fully threaded out.
http://www.summitracing.com/parts/rnb-610-323
Old Jun 13, 2013 | 01:09 AM
Used dorman 323, 1.56 each at car quest...
jazarling
Tires & Wheels
May 11, 2015 04:15 PM
tplyons
Tires & Wheels
12
Jun 29, 2010 10:01 PM
2tweaked
"How To" Tutorial Library
Oct 4, 2008 10:58 AM
The Curly 1
Sep 19, 2008 07:14 AM
orange08
Aug 30, 2008 11:05 PM
