looking for new tires!
Old Mar 15, 2010 | 11:13 AM
nomadtgif's Avatar
I want to re[lace my stock tires, which are P215/55 R16 too a higher profile tire like a 65 or 70. Does anyone know what is the largest tire size that I can put on my 2006?
Old Mar 15, 2010 | 11:21 AM
solman98's Avatar
You can play with some sizes here.
http://www.1010tires.com/TireSizeCal...?action=submit
But I would stay under 26.25" due to the botton strut spring plate. These are the tires I just put on, they are right at 26" tall. You can see what clearance is left.
Old Mar 15, 2010 | 06:20 PM
nomadtgif's Avatar
Thumbs up New tires for my 2006
Thanks for the web site and the advice, I think I can safely put 195/65-R16's on it without any problums.
Old Mar 15, 2010 | 08:56 PM
harleysshhr's Avatar
you can go to 215/60r16 tires and still clear the strut. I don't know what you are trying to achieve, but this size has a little more sidewall height than the 195/65r15 tire that you mentioned. You will also find it to be more avaliable in many more tire brands and tread designs. So if you are trying to go to the most sidewall height and still use the 16" rim this tire would be it. Also the 195 width might be to skinny and not be able to carry the proper weight for the vehicle with a load in it.
Old Mar 15, 2010 | 09:03 PM
Sandmanse7en's Avatar
What are you planning, white walls, I guess I usually think along the lines of lower profile.
Old Mar 15, 2010 | 09:09 PM
Maybe ride, some people actually think that the ride comes from the tires sidewall instead of the car's suspension which is totally incorrect.
Old Mar 15, 2010 | 09:53 PM
mongo's Avatar
Need proof.
Old Mar 15, 2010 | 10:38 PM
try this:
1. partially clamp your springs down and then take a ride
2. unclamp your springs and pump the tires to 50 PSI and then take another ride.
I think you will agree with me that the ride truely comes from the suspension.
Old Mar 16, 2010 | 05:36 AM
solman98's Avatar
try this:
I will agree that most comes from the suspension, but the tires do play in that also. I noticed it the day I went from a 215/55R16 to a 225/40R18. It was a little stiffer. Sidewall flex is part of the suspension.
Old Mar 16, 2010 | 08:21 AM
mongo's Avatar
try this:
Try this:
1: remove your wheels
2: replace with bare steel rims and take a ride.
3: Tell me again how tires have no impact on ride quality.
