Newbie with same old wheel and tire questions
Old Nov 5, 2017 | 08:44 PM
Originally Posted by Ohirolina
Is there an easy way to make any of the sizes I mentioned above work?
No. Not only are they the wrong bolt pattern, they have 0 offset.
Here is a link to AR wheels that fit http://www.americanracing.com/wheels...wse-wheels.cfm
Old Nov 5, 2017 | 11:31 PM
Ohirolina's Avatar
Thank You very much!
Old Feb 3, 2018 | 08:11 AM
Drifter..'s Avatar
I put 215-55-17s on my wifes car, ride is Far better than the 215-45-17s that were on it and they fill the wheel wells no rubbing.The 55s give it more of an old school look. 16in wheels with bigger tires look even better!
Old Feb 3, 2018 | 08:24 AM
215-45-17's were not a factory size for the HHR. That size is a lot shorter than stock size that should be on there.
Yep. Short, skinny, no sidewall tire. Bet it did ride harsh and rough.
Old Feb 5, 2018 | 03:55 PM
Drifter..'s Avatar
Yes it rode harsh and beat the front end parts to death. They were on the car when purchased. New parts and tires almost like a new car again! I have seen HHRs around here with 18 or 20 in wheels with rubber bands for tires that has to be a brutal ride. I would like to have some 16in steel rally wheels with big old school tires i draw the line with white walls though......before my time!
Old Feb 5, 2018 | 04:01 PM
No, but contact AR perhaps they’ll make you a set in the correct 5X110 mm with a 42 mm offset.
Old Feb 7, 2018 | 09:03 AM
Cat Man HHR's Avatar
The 215/55's should as they have a taller sidewall which is a better "shock absorber" then the other ones. Also the compound of the tire makes a difference. A 30K tire wears faster but is a softer compound than a 50K tire. Running tire pressures at 30 psi will also make for a softer ride than at 35 psi.
Old Feb 7, 2018 | 03:51 PM
If you really care what is "supposed" to be on the car you can look at the tire placard stuck on the driver door frame.
Old Feb 8, 2018 | 06:14 PM
Of course there are lots of changes that don't match the sticker - that goes without saying. I have an idea what your point might be, but don't want to assume what it is.
Old Feb 9, 2018 | 07:24 AM
So you put red tail lights in place of your headlights??
That doesn’t make any sense at all, let’s keep to a helping informational response
