Nitrogen Tire Inflation
I would not term it misleading. But I would term it over selling a small gain.
Nitrogen in tech terms is better but is it really a must have or that great of an advantage to have that it is worth the trouble of finding it and paying $28.
These are terms each driver needs to ask him or her self.
This is no different than oil and it just comes down to the end user.
What I am trying to say there is no wrong answer here and only the right one you make for yourself. So there is no need to argue the point here.
I myseld have better things to so with my money but if someone feels better using it so be it. Using it will not hurt anything and if it make one feel better then it is worth the $28 to them.
I believe ALMOST everything you stated. But can you explain how nitrogen PREVENTS CORROSION IN ALUMINUM OR MAGNESIUM WHEELS. I was under the impression that common moisture has very little effect, if any, on these two metals. That's one of the reasons why they are used in the marine industry.
I thought I got suckered into a Tornado purchase, but I did some checking after installation and found that I did average about 1.5 miles per gallon better over the course of a year in a V8 truck that I had. It's not much, but it did help and justified the cost of the unit as it paid for itself. Another product that will boost HP a bit is Lucas fuel additive. It also boosts octane rating. I have noticed 2 mpg improvement with it and better/smoother throttle response. Try it sometime, it's worth the $$$.
We sell Tornado's at work and I have yet to see anyone provide proof on a Dyno or paper that will honestly and independently back it up.
As for Lucus we also sell their products and they do offer some good products but I find it hard that it improved mileage 2 MPG unless it has corrected a problem with the vehicle.
The bottom line is if things like this improved milege so easy and cheap every Auto MFG in the world would either be using them or using a copy of them. As it is they are spending millions of dollars to redesign fuel systems like new DI systems and entire vehicles just to pick up 2-3 MPG.
How many got took on past things like Slick 50, Splitfire plugs and those magnets you tape on the fuel line? The goverment has shut some of these down on their claims and I expect to see more with increase gas prices in the future.
Sorry, I am just a non believer based on lack of proof.
Been there done that and ain't never going back.
bigbear2k
Tires & Wheels
35
May 2, 2008 09:13 PM
cj krause
Tires & Wheels
Aug 3, 2006 06:46 PM
