Ordered new rims for the SS
Old Apr 12, 2010 | 07:49 PM
panoptikos's Avatar
spacers
Are the 5 x 110 spacers still for sale? I'm interested if they are. Please call Bruce at 716-598-0563.
Old Apr 12, 2010 | 11:12 PM
Originally Posted by HHRSSouth
Just ordered these: SSR type c-rs's 18.4lbs/ea
One of the lightest rims available for our bolt pattern. .
Sharp Rims,
I agree with you about using lightest rims you can. I do it too, even on my Bikes..
I call it free horsepower..It helps..
Old Apr 13, 2010 | 09:58 AM
Father Azmodius's Avatar
I may be wrong, but I recall hearing something like every 7lbs of rotational mass will net 1hp.
Old Apr 13, 2010 | 09:45 PM
HHRSSouth's Avatar
General consensus (depends on the site you go to, I've seen as low as 2lbs. and as high as 10lbs.) is 1lb of rotational mass is about 6-7 lbs of static weight. So I shed about 8 lbs of rotational per wheel, plus 3 lbs per tire on the factory set up, 11lbs. 11x6= 66lbs x 4= 264 lbs static weight.
100 lbs loss = to about .10-.15 sec in 1/4 ET.
The HP will never show up on the Dyno, but rather in acceleration and movement since the engine doesn't have to work as hard to get the wheels moving.
I could be high or low on the poundage depends on where you go to, but the bottom line is the wheels and tires are lighter then factory and I love the way they look.
Old Apr 14, 2010 | 12:42 AM
"The HP will never show up on the Dyno, but rather in acceleration and movement since the engine doesn't have to work as hard to get the wheels moving".
X 2
Old Apr 14, 2010 | 07:29 AM
I knew it was something like that. I know switching to a 520 chain and dropping 20 other lbs off the 675 made a big difference with the butt dyno.
Old Apr 14, 2010 | 08:25 AM
Scrivs's Avatar
Nice choice. My SS is also red and any kind of black/anthracite coloured wheel toughens it up a little. I am looking for a set myself. Show some pics when you have them mounted on the car.
Old Apr 14, 2010 | 12:42 PM
asanti's Avatar
I believe he has pics in his gallery or posted up in the pic/media section here.
Old Apr 14, 2010 | 05:47 PM
bassbase's Avatar
So what preytell are you doing with the stock SS rims......hint, hint.
Old Apr 15, 2010 | 10:24 AM
HHRSSouth's Avatar
As of right now I plan on keeping them, I keep all my factory stuff off new cars I mod, just in case.
