Saturn Sky/Pontiac Solstic rims?
Old Mar 2, 2010 | 08:13 PM
  #31
djr1973's Avatar
Oh one more thing, the bottom of the strut where the coil spring sits in, there is maybe 3/8" in between that and the top of my tire.
Old Mar 2, 2010 | 08:14 PM
  #32
HHRSSouth's Avatar
Originally Posted by djr1973
the bracket I ground is wleded to the strut housing, I only actually groung off about a 1/16 of an inch, by no means will this hurt or affect anything. I am a welder/fabricator for my profession, and if I thought it would be a problem by removing material I wouldnt have done it. I have done custom suspension on other vehicles includeing a custom 4 link suspension with air ride on a ford ranger, and have done suspension work on dirt track race cars. All I am trying to tell you is that if you dont use spacers with solstice/sky wheels, they will rub the sidewall of the tire on that edge of the bracket.
By chance do you know the factory offset of the solstice/sky wheels?
Old Mar 2, 2010 | 08:15 PM
  #33
djr1973's Avatar
I believe it is 55 mm.
Old Mar 2, 2010 | 08:22 PM
  #34
Talvanos's Avatar
i think the HHR is 46mm so I would need about a 9mm spacer, just shy of 3/8" at .354"
Old Mar 2, 2010 | 08:27 PM
  #35
djr1973's Avatar
I am not trying to sound rude or be an ass, but I am just telling you what I had to do, and also I have talked to other members with the same wheels as me and they said the same thing about having to shim the wheel out and that a 245/45R18 will not fit up front without rubbing the strut where the bottom of the coil spring sits.
Old Mar 2, 2010 | 09:03 PM
  #36
Talvanos's Avatar
I didnt take it as such. 8-D Infact I have taken to quit the contrary. I am keeping in mind that I will probably have to do that anyways. I really do appreciate all your help, and hope I didnt come off wrong.
Old Apr 30, 2010 | 11:30 AM
  #37
wagoneer's Avatar
Here is a good site for matching up the HHR's 110 bolt pattern with other stock rims.http://www.roadkillcustoms.com/hot-r...udSpreadMM=110
Old Aug 16, 2010 | 02:05 AM
  #38
BeanWagon's Avatar
Does anyone know if 245/40 18" fit. I was reading some people putting them on their SS rims. I'm assuming they had more clearance because of the 1/2 inch difference between the stock SS rims and the wider Solstice rims. Any thoughts or suggestions? Because I'm going to be buying some tires next week for my solstice wheels.
Old Oct 8, 2010 | 11:34 PM
  #39
gangster moblie's Avatar
ive got 08 hhr lt that i just put 5 spoke chrome wheels off a pontiac solstic with no mods n no problems with 225 45 18s no rubn nothen no grindn maybe i got special ones lol.. i was thinking of running 20s in the front n 22s in the back make it more hoty rodish wonder if 22s will fit in the back.
Old Jun 23, 2011 | 02:29 PM
  #40
Mowgli's Avatar
My mechanic said that different sizes front/back will screw with the ABS and possibly other stuff.
Infinitys & Nassans that use different sizes are calibrated for that.
