Sensor TPMS
GM part number 25920615 has been replaced by GM part number 20923680. This is the correct part number for the HHR.
The new part number is available here...
http://www.gmpartsgiant.com/parts/gm...-25920615.html
GM part number 15268606, will not work on the HHR.
This is not to believe?
Unfortunately the individual has made an error in their e-Bay listing, they have the wrong last digit on the part number. The correct part number is 15268606, which will work on the Chevrolet Uplander minivan(but not on an HHR), the part number they have accidentally listed (15268608), is for a windshield washer nozzle.
TPMS sensors transmit to the vehicle on a set frequency, the sensors in the e-Bay listing transmit at a frequency that is not compatible with the HHR's TPMS system.
TPMS Sensor Tire Tyre Pressure Sensor Tire Pressure Monitor System
FIT FOR: Chevrolet HHR
OE NO.: 15268606
Megahertz: 315MHZ
Type: Electric
OE NO.: 25920615
Megahertz: 315MHZ
Type: Electric
OE NO.: 15268606
Megahertz: 315MHZ
Type: Electric
OE NO.: 25920615
Megahertz: 315MHZ
Type: Electric
My apologies for a mental slip, the HHR does use a frequency of 315MHz (actually 314.90-315.10MHz), it would be an issue of telemetry data being incompatible when the wrong TPMS sensors are used.
They would transmit on the correct frequency, but the vehicle would not recognize the data, or the data would be presented incorrectly.
