Sensor TPMS
Old Apr 28, 2013 | 10:17 AM
iroga65's Avatar
Thanks.
Old Apr 28, 2013 | 11:48 AM
The tool just sends a RF signal to the sensor to activate the "learn" mode. On a 2008 model that is exactly the same as the "inflate/deflate" procedure. So, no it would not help.
However the EL-46079 tool may do the job, the Ateq VT-30 may also do the job. These tools read the I.D. of the sensor, then insert it into the RCDLR.
Old Apr 28, 2013 | 12:40 PM
iroga65's Avatar
EL-46079 too expensive and not available to me.Thanks.
Old Apr 28, 2013 | 12:51 PM
iroga65's Avatar
And with GM TECH 2 will not work?
Old Apr 28, 2013 | 01:40 PM
I am not sure about the Tech 2, but probably would. You would need somebody who is trained.
Old Apr 29, 2013 | 04:57 AM
iroga65's Avatar
15268606 can also be installed in HHR SS instead of 25920615.
http://www.gmpartsgiant.com/Page_Pro...=2&SupplGroup=
http://www.gmpartsgiant.com/Page_Pro...X=&SupplGroup=
Old Apr 30, 2013 | 08:15 PM
CopterDr's Avatar
How do you change the tire pressure sensor?
Old Apr 30, 2013 | 08:56 PM
iroga65's Avatar
What do you mean "how"?
One set of wheels with sensors 25920615. Second with 15268606. Hence, the question arose.
Old Apr 30, 2013 | 09:19 PM
Basically you go to a tire store and have them do it, with either parts you bring with you or bought from them. Unless you happen to have a tire mounting machine.
ecaryn
May 3, 2017 11:35 PM
esmarkey
Tires & Wheels
10
Sep 5, 2014 09:22 AM
wayne stewart
Tires & Wheels
0
Mar 25, 2013 02:15 PM
Dennis Puskar
Tires & Wheels
Dec 27, 2011 10:36 PM
BlackknighT
Aug 19, 2011 07:15 PM
