Solstice wheels?
Old Jan 5, 2009 | 08:43 AM
solman98's Avatar
Originally Posted by catdaddy137
you are right. but a 50 is wider than a 60. and a 245 is taller than a 215. you are right .but i still refer to it as i just stated , i am not a mathematition , or the winner of the spelling bee. but i know a little about tires , wheels , cars , anything with a motor or wheels. i just think it is less confusing to say that the larger the larger # the taller the tire , and the smaller the smaller # the wider the tire. anyhoo , this still doesn't anwser any of my questions.
A 235 should fit with no problem width wise. You can compare your stock to those here....
http://www.1010tires.com/TireSizeCal...?action=submit
Old Jan 5, 2009 | 08:53 AM
The Curly 1's Avatar
Tires
245-45-18 tires will NOT fit on the front. It hits the strut hard. On the rear you can trim a whole bunch out of the plastic fender wells to make it work.
I reccomend using the 225-45-18 tires all the way around.
Old Jan 5, 2009 | 09:02 AM
catdaddy137's Avatar
thanks , but ,
i thunk me said 17s? i wish i had 18s , or 20s. i have 215 50 17 , i am cosidering , 235 55 17. thanks for all info , it helps even if it is not specific to my delimas. it may help someone else , and also give me some ideas. i'd much rather learn from someone else, these lessons can get quite expensive.
Old Jan 5, 2009 | 09:04 AM
solman98's Avatar
Were the spacers required with the smaller tire?
Old Jan 5, 2009 | 05:52 PM
Fuzzbuster's Avatar
NOT TRUE!
A 285/70 is wider than a 225/50 by 60mm...total width
and a 215/75 is taller than a 275/40 total height
50 has nothing to do with width and 245 has nothing to do with how tall a tire is other than determining the height of sidewall depending on second nomber
your doin it backwards man...
i`m pretty sure on that
Old Jan 6, 2009 | 06:05 AM
Solstice wheels ar 18"
Solstice wheels are 18" I do not know if the 235-40-17?(18"?) will fit. I know the 245-45-18 will definatly not fit as it hits hard on the strut. Too tall and too wide. The 225-45-18's fit with the spacers but there still is not much room from strut and brake calipers. Hits calipers with out spacers.
Old Jan 6, 2009 | 08:38 AM
solman98's Avatar
Thanks for the info, guess I will pass on these, If I have to buy tires, might as well just buy new rims with the correct backspacing so I can run a 235 without clearance issues. I know several are indeed running 234/40 18's with no problems. Guess the RWD offset of the Solstice just thows it off that much. But don't need tires yet, so I just keep my eyes open for now....
Old Jan 6, 2009 | 08:45 AM
True, but the thread is about 18's.
Old Jan 6, 2009 | 08:53 AM
I run 225-45-18's with no problems and mine is lowered. The biggest issue is the offset when dealing with the HHR, and as Curly said, the front is the hardest place because of the struts.
Old Jan 9, 2009 | 01:27 AM
caroftheweek's Avatar
Will the 245 fit on an HHR that is not lowered or is there still clearance issues with the strut?
By the way, how does the HHR ride with 3rd gen Goldlines as compared to stock?
