tire size
Old Nov 1, 2013 | 04:41 PM
jd0225's Avatar
tire size
I have a 09 hhr I want to chang tire size from a 215 55 16 to a 215 60 16 is that possible? I want to get away from the performance tire that was put on at the factory.
Old Nov 1, 2013 | 05:22 PM
Yes,and usually cheaper sometimes with a longer warranty and a lower speed rating (113MPH instead of 121MPH). I would not call the factory tires "performance", most people use the word "crap".
Much discussed topic, use the search tool.
Old Nov 27, 2013 | 02:51 PM
willyradio11's Avatar
tirers for my HHR Panel
So what your saying is the 215/60 16 will work on my 2011 Panel ?
Old Nov 27, 2013 | 04:10 PM
Assuming you have 16" rims, yes. But be aware of the different speedo reading, it will say your are going a couple of MPH slower than you are. Calibrate with GPS.
Old Nov 27, 2013 | 05:02 PM
Blue_SS's Avatar
Here's a tire calculator that can help you "try" different sizes, and see the speedo error that results from them. I used to use it when I was trying to improve my gearing in a previous car for autocross.
http://www.miata.net/garage/tirecalc.html
Assuming you are shooting for more comfort, you may want to try something narrower and higher profile. Like a 205-60-16, maybe. Ideally, you'd like to maintain the same outer diameter and add rubber in this case.
Old Nov 27, 2013 | 05:20 PM
Oddly enough my 2011 with stock 215 55 X 16 had a speedo error of about 2 MPH too high at 65MPH. I put 215 60 X16 on it and the speedo now agrees with my GPS.
hurst2001
Tires & Wheels
Jan 5, 2015 08:48 PM
cmidd555
Tires & Wheels
Sep 13, 2014 10:08 PM
mmont50
Tires & Wheels
20
Sep 13, 2012 11:57 PM
little red
Feb 24, 2009 05:40 AM
jayhawker
Tires & Wheels
Apr 7, 2008 06:42 PM
