Wheel specs
Old Sep 14, 2017 | 11:22 AM
racing123's Avatar
Wheel specs
What are the spec's for the steel wheels OEM. Size, offset Etc. tnx / Ron
Old Sep 14, 2017 | 01:05 PM
5 X 110 bolt circle about 42mm offset usually 16 X 6.5.
Old Sep 14, 2017 | 01:06 PM
prod's Avatar
The base steelies are 16", 5x110 bolt pattern, 42mm offset.
EDIT: looks like donbrew was the quicker clicker.... this time.
Old Sep 14, 2017 | 01:23 PM
Ron, I gave your thread a new title, so people will know what it is about before they click on it. I also moved it to the appropriate forum, tires and wheels.
Old Sep 14, 2017 | 01:24 PM
racing123's Avatar
2009 Panel
tnx / guys
Old Sep 14, 2017 | 03:35 PM
Base steelies as mentioned those sizes are correct
Old Jan 18, 2020 | 01:20 PM
Bill VonSteuben's Avatar
Old thread, but I didn't find the centerhole size. I want to mount my summer tires on spare wheels so I don't have to mount and dismount 2x a year. Looking at 16 inch Vibe wheels-bolt pattern fits but the centerhole is 40 something rather than 60something. Is that a disqualifier?
Old Jan 18, 2020 | 01:59 PM
Cat Man HHR's Avatar
OK explain Vibe wheels ?
Also 40 is smaller than 60. I guess you mean that's in Millimeter ?
I think you answered your own question.
If they did work. What is the rim width and back spacing ?
Old Jan 18, 2020 | 02:44 PM
Pontiac Vibe does not use 5x110 wheels
Old Jan 18, 2020 | 03:02 PM
The HHR hub OD is 65.1 mm
https://www.chevyhhr.net/forums/tire...c-rings-48853/
