Would these lugs fit my steelies?
Old Jul 18, 2011 | 04:47 PM
pstar's Avatar
I have the '09 LT. I'm running naked steelies and want to replace the lugs with a black set to match. Would these fit? Thx.
http://cgi.ebay.com/ebaymotors/25-BU...mZ180664734664
"PITCH - M12 X P1.5
COLOR - BLACK CHROME
SIZE OF LUG NUT: WIDTH 23mm / LENGTH 36mm
MADE FROM FORGED 50BV30 STEEL, EACH LUG NUT WEIGHT LESS THAN 1.5 OZ.
WILL FIT MOST AFTERMARKET WHEELS AND SOME STOCK WHEELS WITH 60 DEGREES ACORN SEAT."
Old Jul 18, 2011 | 04:58 PM
Well the size and thread pitch are right, I think they'd work for you. Check out this thread and you might want to click the link in the thread to TruckSHOP.com, they are good for wheel and lug nut questions.
https://www.chevyhhr.net/forums/show...=stock+lugnuts
Old Jul 18, 2011 | 05:17 PM
I'm wondering about that 60 degree seat though.... are steelies that steep an angle?
Old Jul 18, 2011 | 05:57 PM
Yeah the seat angle might be too severe, that's why I suggested at call to the guys at TruckSHOP, or someplace like it.
Old Jul 18, 2011 | 06:39 PM
Snoopy's Avatar
Remove one of your lugs and look at the profile. Determine if it has the questionable angle.
Old Jul 18, 2011 | 10:43 PM
pstar's Avatar
It's hard to find any info on this. Not many shops advertise the seat angle. The ones I've found indicate it is a 60 degree angle. I'll pull a nut and see if I can compare it. Thanks.
http://www.titanwheelaccessories.com...fid=p113-c9051
Old Jul 19, 2011 | 07:58 AM
JavaMann's Avatar
You're a braver man than I.
Old Jul 20, 2011 | 08:17 PM
Was thinking about this the other day...... (I know, it makes my brain hurt)
I use the stock lugnuts that came with the 2LT alloy wheels on my Euromax 612 alloy wheels, I would imagine they are 60 degree as are most alloy wheels. They are also meant to be used on the factory "stupid spare" which is a standard steel wheel lugnut configuration....... Not "proof" but I would think anything of that angle would work.
Take it with a grain of salt.
Old Jul 22, 2011 | 06:01 PM
pstar's Avatar
Thanks for all the feedback. I've got those lugs ordered and enroute now. I pulled of the oem lugs and per my eye ball comparision, they look the same.
I located a dust cap to cover the front hub nasty area and I've painted the rear drums and axle end plate with high temp caliper paint. Once I receive the nuts I'll post a pic of my cheapo steelie dress up project. Again, thanks for the help.
Old Jul 22, 2011 | 06:31 PM
