Mods while engine out
Old 02-19-2012, 09:55 AM
shirer61's Avatar
fixin to put a new engine in a 2006 2.2, while engine is out what are some recommended easy mods, i see the 2.4 intake is a good one, new here thanks for the help
shirer61 is offline
Old 02-19-2012, 10:07 AM
TICITRD's Avatar
Welcome Good luck with the engine.
TICITRD is offline
Old 02-19-2012, 09:39 PM
IgottaWoody's Avatar
400 small block comes to mind...hmm...plus a big shiny noisey air masher on top!
IgottaWoody is offline
Old 02-19-2012, 11:51 PM
Port match & blend the 2.2 head to the 2.4 intake.
sleeper is offline
Old 02-20-2012, 12:33 PM
prod's Avatar
Perhaps painting/powdercoating some of it, if you care for that. I probably would, but I show mine a few times a year.
prod is offline
Old 02-20-2012, 02:53 PM
SmootHHR's Avatar
Maybe a cam? I'm just dreamin with your $$ :)
SmootHHR is offline
Old 02-20-2012, 11:51 PM
To swap cams (2 of em), OP would need to get a 'tune' & maybe bigger fuel injectors..
sleeper is offline
Old 02-21-2012, 07:01 AM
SmootHHR's Avatar
You're dreaming with his $$ too While the motor is out would be the best time.
SmootHHR is offline
Old 02-21-2012, 08:54 AM
07azhhr's Avatar
From all the reading I could find on the 2.4 intake it is the 05-07 Cobalt SS version of the intake manifold. It is the only version to be a one piece cast. The others are two piece castings and look to neck down similar to our 2.2l intakes. So when looking for this be sure to look for the one piece. I can only find the one piece at Crate whatever dot com and for over $500. For that price vs the gains I would save for a supercharger or turbo but that is just me. If you do decide to do cams and any head work then that intake would be very worthwhile. Also keep in mind that for the most gains from the mani swap you also need a tune and they are near or above $300 for our cars so you would then be very close to a grand. You could piece a supercharger kit for that price or slightly more but you would still need the tune. But gains would be much higher and thru the entire powerband.
07azhhr is offline
Old 02-21-2012, 09:13 AM
Rest In Peace
American & Proud's Avatar
As long as you got it out, might as well just go for it.
American & Proud is offline
Quick Reply: Mods while engine out
