Cooling fan start UP temp?
Old 09-24-2009, 01:31 PM
Snoopy's Avatar
Originally Posted by RaineMan
Coming from a Cobalt SS to a 2.4HHR I can tell you... this thing runs HOT. If I'm just sitting idling the coolant temp will get above 220 pretty easily.
Honestly I don't see it as a big problem... the car seems to run just fine either way.
If you are that concerned, you can command the fans on at a lower temp through HPTuners.
Are you indicating you had the A/C ON while you were idling??? If so, that is pretty strange. I have sat and Idled with my A/C on for 20-40 minutes....never went over 208. AND THAT IS IN AMBIENT TEMP.'S of 115 F.
If your A/C was off that is understandable. The fans weren't running and no air was moving thru the radiator/coolant.
Snoopy is offline
Patr
07-02-2022 06:50 AM
Leemor
06-09-2014 06:33 AM
ltishea
06-14-2012 09:46 AM
HHR Rock's
07-02-2009 08:45 AM
kornellred
08-26-2007 06:39 AM
Quick Reply: Cooling fan start UP temp?
