Saab 9.3 2.0t Intake Manifold / Throttle Body for LE5 2.4L?
Old 09-07-2016, 02:46 PM
clintsal's Avatar
I just came across a craigslist ad for a "2004 saab 9.3 2.0t intake manifold with throttle body".. Is this the same as a LSJ IM and TB? And if so, would this be a good investment (it's cheap) for future engine build-up on my 2LT 2.4L LE5 ?
If this will fit, I understand it will need a TB spacing / wiring adapter from ZZP, and a tune.. Anything else?
Thanks for any info!
clintsal is offline
Old 09-10-2016, 10:51 AM
hhrfreek's Avatar
Not at all like an LSJ intake. I'd stop and forget about this. The stock mani and tb are really not limiting your power. Best way to add power is to go with boost. If you turbo you can use your stock mani. If you SC then youd need an LSJ mani.
hhrfreek is offline
Old 09-11-2016, 08:27 AM
Dbeluscak's Avatar
@clintsal
- I think you're on the right track. 04 seems a bit early but I'd bet you can contact ZZP and ask what Saab years will work. ZZP uses a modified Saab intake for their LSJ turbo kit.
Ecotec Parts LSJ Turbo Intake Manifold
@hhrfreak
How much boost will the plastic manifold hold? I would assume not much. I'd like to try it and find out though!
Dbeluscak is offline
Old 09-11-2016, 08:44 AM
Technical Moderator
Sounds like a job for Myth Busters! KABOOM!
donbrew is offline
Old 09-11-2016, 07:18 PM
To much boost?
Oldblue is offline
Old 09-15-2016, 06:30 AM
hhrfreek's Avatar
The stock mani will hold more boost than the bottom end will.
hhrfreek is offline
Old 09-15-2016, 06:45 AM
I also wondered about the stock plastic manifold. But it makes sense, the stock charge piping is plastic, too.
RJ_RS_SS_350 is offline
JCC
09-03-2015 12:05 AM
cipher
06-13-2007 09:06 PM
Quick Reply: Saab 9.3 2.0t Intake Manifold / Throttle Body for LE5 2.4L?
