TTR Upper Engine Mount
Old 12-07-2014, 09:18 PM
  #111
No, like I said, I found all this on cobaltss forum. If I had the shop manual, I would not be asking for help.
RJ_RS_SS_350 is online now
Old 12-13-2014, 05:15 AM
  #112
[QUOTE=RJ_RS_SS_350;766011]Just got the engine mount and the STOP trans mounts. Hoping to install on Monday or Tuesday. I found these torque specs over at cobaltss. Are all these specs correct for HHR? Do I need to mess with frame-to-body bolts and Input Shaft Bearing Retainer Bolts?
I looked at the list of torque specs in the repair manual. It seems your list that you posted was just someones copy/paste from the manual.
The input shaft retainer bolts specs just happened to be "alphabeticallly" in that spot. Those aren't bolts you'll need to mess with.
I haven't done STOP mounts, so can't really give advice there.
firemangeorge is offline
Old 12-13-2014, 02:21 PM
  #113
Thanks George, that's very helpful. I hadn't intended on doing the STOP mounts, either, but their website wouldn't let me order the engine mount alone. I figured what the heck, may as well do the STOP as well. Thanks again
Old 12-13-2014, 02:35 PM
  #114
Wouldn't let you order the front mount alone ??? I think there must be a mistake somewhere.
I got the front mount alone from TTR and I recall many others on this site that have gotten the front mount by itself.
Old 12-13-2014, 04:52 PM
  #115
When I tried to order, it said 'transmission upgrade is required'. Now i see an option for 'none', that allows the mount alone to go in the shopping cart. Either it wasn't there before, or I just didn't see it before. Either way, 'none' should be the default. But I don't regret getting the STOP mounts. Just waiting for some good weather so I can install these.
Old 01-04-2015, 11:45 AM
  #116
Former Sponsor
TurboTechRacing's Avatar
More in stock and shipping.
TurboTechRacing is offline
Old 01-12-2015, 05:42 PM
  #117
Finally got the engine mount and the STOP mounts in. What a difference!! Feels much more powerful, torque steer is gone, and I'm not feeling any vibrations at all. Engine/exhaust is noticeably louder, is that to be expected?
Aaron, you may want to revise the instructions, specifically, for the STOP mounts, a shallow 18mm socket is needed, for the engine mount, a deepwell 18mm socket is needed. Thanks, satisfied customer!
Old 02-12-2015, 07:47 PM
  #118
Former Sponsor
Will get that over to the guy who updates the manuals.
Also most likely louder as the engine/drivetrains is more connected to the frame, and you hear the exhaust a bit more.
Thanks for the awesome review!
Old 09-23-2015, 06:38 PM
  #119
Former Sponsor
More in stock and ready to ship.
Old 10-11-2015, 11:08 AM
  #120
rlee63a4's Avatar
After 15,000 miles, motor mount still functioning as advertised, but powder coating flaking off.
rlee63a4 is offline
