CNG, Auto-Gaz Centrum, sequential (multi-port) injection system
Type 1,2,3,4 tanks are all still being produced. The type of tank has no bearing on age. Only material it is manufactured from. They all have to pass the same test requirements. The tanks I have. the PRD's are on the side, not rear and date code till 2018. When they expire and if I still have the car. I will update tanks at that time. I'm fully aware of the safety involved and do appreciate you looking out for my safety in this matter. Thanks, Jim
My mis-reading. I though you were stating no cage around PRD's. Yes there is a cage around tanks.
The tanks look like they are factory wrapped in cf.
This is really cool, I can remember when hot rod mag did a story on a cng Lincoln, everybody was scratching their heads over it.
My question would be what happens when tank pressure gets low??
Now the really cool part is being able to keep a 500 gallon tank on you property, the govt won't let you do that with a gas pump.
I was seriously considering this until I got an estimate on total installation cost from CNG United. This is their quote, "Thank you so much for emailing
us regarding your interest in converting your 4cyl. Chevy to CNG.
As you already know, the retail cost of a CNG U AG/PRO 4cyl. conversion kit is $1425.
You will also need a NGV ( Natural Gas Valve ) - $170, a CNG tank ( the tank size
and price depends on the size of your vehicle ). I will send you our tank pricing
sheet. Mounting Brackets for the tank - $225, Installation depends on the CNG
mechanic in your area - $4500 - $6000, and shipping and freight - $280." If I am reading this right this does not include the cost of a tank(s). I've kind of lost interest, that is more than half the cost of the vehicle plus what ever the tank costs! Another question, does all this work with my current on board computer(ecu/ecm) or do I have to find someone that can do reprograming and at what cost?
#26
I feel almost everything related to CNG is way over priced. The kit is excellent for the money. Tanks, brackets, valves, filters, fittings are all over priced. Labor as well is about double of what one should have to pay.
It is alot of work to install. Very time consuming, if you want a clean and safe install. I'm completing an stall a C
CNG kit now on a 2007 F-150 and quoted $2000.00. Looking back, I should have quoted at least $2500-$3000. That's about half of what they quoted you.
#27
Selling CNG mobile. For Sale
See if it might fit your needs.
https://www.chevyhhr.net/forums/show...008#post672008
#28
As for the system installed by the original poster, can you tell me if this system has been working well for you? We have been contacted by this distributer to be an authorize installer for it and I would like to know more on how it has been running.
Sara@wisegasinc.com
#29
I know this is an old thread, but I just found it. There are cheaper alternatives than CNG United if you are in a non-CARB state. I work for Wise Gas Inc and most of our system run $6,500-$8,500 with the tank and installation.
Sara@wisegasinc.com
Sara@wisegasinc.com
AG Centrum works perfect on both the installs I've done. The price range you are giving, would be about the same install price of most multi-port systems that aren't EPA certified.
jmule
08-10-2015 11:21 AM
