Fuel Economy - Hypermiling Dedicated to discussions on fuel economy improvements and related modifications.
Whats your gas mileage on your HHR
Old 04-20-2016, 11:48 AM
  #141
chaosdsm's Avatar
Originally Posted by Oldblue
As you can see if still have my Woolyworm, I might just swap over to my steel dryer tube to test that !
Would be interesting as another data point... I'm guessing it won't do a whole lot more though. Your 'worm' looks (from the photo) to be in decent shape, but my 'worm' was in bad shape & was definitely restricting airflow to some degree.
chaosdsm is offline
Old 05-30-2017, 10:32 AM
  #142
Bob109's Avatar
Well today I am at 34,395 miles on the odometer with my 2009 2.4L 2LT, from 27,xxx when I bought the HHR in Nov. So that's right at 7,000 mi. over all, city highway, driving like I stole it once in a while (I can assure all, there is no carbon build up) to running to the store 1/4 mile away, you name it, all driving conditions, below 20* when the roads are dry and clear, to 70* some days this spring. no summer over 70* temps driving, which I would expect to be better.
31.3 mpg for those 7000 miles, almost all of it on 87 octain with the 2.4L engine, and that is because, I see absolutely no difference running 92 octain in MPG or performance. And that with the A/C running most of the time with the defrosters on. I checked the DIC for over 1600 miles keeping my own records, and was always within .1 mpg over or under every fill up, so the DIC is accurate, or at least mine is.
That will be changing as I am installing the hitch, and will be pulling one of the 2 boats with it most of the time this summer. One is 15'9" the other 12'11". Both fully rigged for fishing. I will reset the dic and see if I can average 25 mpg. If I can I will be happy, that will be better than the 15.4 I average with the Suburban! We shall see?
Bob109 is offline
Old 07-07-2017, 12:22 PM
  #143
JazzDad's Avatar
128K miles. Mixed driving, average 30.3 MPG. Including an EMS or fire response, 28 MPG. Still the original brakes.
JazzDad is offline
Old 07-11-2017, 09:13 AM
  #144
aradmahogany's Avatar
GRRR Gregg at his best is just under 28 MPG Combined. All tuned up, too. What am I doing wrong?
aradmahogany is offline
Old 07-11-2017, 09:20 AM
  #145
You must be responding to too many fires.
Or maybe it's all those times people are surprised at how fast Gregg is.
Or maybe all the racing stripes.
RJ_RS_SS_350 is online now
Old 07-11-2017, 09:23 AM
  #146
PittKrewBowling's Avatar
City driving, DIC reads 22.1 but I calculated 23.1 - going to change air filter and try a tank of hi-test and see what happens.
PittKrewBowling is offline
Old 07-11-2017, 09:24 AM
  #147
Well, when I baby him the mpg's do go up. I can not help it if he likes to GO. Getting up to 30+ MPG must be so... BORING. No offense. I do run 93 so it cost me a tad more money but I SWEAR there is a difference.
Old 07-11-2017, 12:28 PM
  #148
Bob109's Avatar
I find 99% of my time I'm driving 5 mph over the speed limit,, I outgrew that 1% of my driving where I liked tearing things up and pouring my money out going to the same place. Took me a while but I finally figured out 1 or minutes a trip was not really worth it,,
I also found out how much more I save slowing down than I do taking off. I have learned to let off the gas way before I have to use the brakes, and watch just how far I travel with the DIC showing 99 inst mpg, coming up on turns and stops!
Not to mention how much longer my brakes last when I don't have to use them for them last minuet stops. I kinda do get board though not needing to shop for a vehicle as often as I used to when I had them exciting few second taking off.
All this makes me wonder why I used to have to work on my vehicles more than some others had to. I find driving much more exciting than dumping money on parts fixing it after the money burnt on my exciting 6 second take offs,, but maybe thats because after owning 65 Impala SS, 68 GTO, 69 442, 70 Chevelle SS, 69 Nova SS,,,, I really do understand exciting over boring? Trust me,, those cars were exciting!
Bob109 is offline
Old 07-12-2017, 09:24 AM
  #149
Well, let me clarify; Although I drive in a "spirited" manor, I never floor, it, I never take off from a dig aggressively, normally I roll on the throttle when driving, and I usually stay about 5 MPH above the speed limit, so typically I am cruising at 60 most of the time. I do however, enjoy how nicely the car pulls at speed, so I do have a tendency to push the throttle and the car kicks down a gear or so, but never full throttle. I do hit a good amount of stop and go on my way home. The DMV tells me I drive a "Sport Wagon" so I treat Gregg as such, though I am nice about it. I mean, I am getting better mileage than the EPA estimated, but I just dont see how people are getting into the 30's. and RJ, the stripes add AT LEAST 5 HP and 3 LB/FT, as well as streamlining the body so it should help with aerodynamics; thats why I installed the rear SS spoiler; it helps disperse the air just like on the SS's giving better mileage. I need to show people why the hood says POWERED BY ECOTEC, and what "TURBO TECH RACING" is. Also, I dont have Torq Thrust style rims for no reason!(YES I am kidding with all this). I do get a fair amount of thumbs up, and compliments on the color.
Old 07-12-2017, 02:14 PM
  #150
Okay... The problem, as I see it is simple. You should "floor it".
Greybeard999 is offline
Quick Reply: Whats your gas mileage on your HHR
