need help--removing door panels
what am I going to run into? do I just pull it off or are there things I need to disconnect?
any info related to this is helpful. Thanks
Originally Posted by teech
check out Captain Howdy's speaker swap in the How-To section
Got them off. Two bolts in each door pocket and then one behind the handle. Then it comes off real easy.
These are instuctions from repair manual. for door panel removal, hope they help.
1- Door armrest,pull cup liner.
2- Remove 2 cup screws.
3- Door inside handle cover.
4- Remove door handle screw.
5- Remove door panel, there are 9 panel clips.
Hope this helps, if you have'nt already figuered it out. Can send a diagram if needed.
Dutchman09
0
08-04-2010 06:23 PM
