Oil fill cap, a little tip
Old 09-22-2007, 06:36 PM
Lone Ranger's Avatar
Thumbs up Oil fill cap, a little tip
Noticed that if you just screw the oil fill cap on it will sit a little crooked to the fill tube, not seated flattly. Give it a push down to seat it after the old clockwise turn is done.
This is with the cap on the fill tube extension, the stock setup. Don't know if this happens when the cap is installed directly onto the valve cover oil fill hole for those who do not use the stock engine cover/aircleaner.
Lone Ranger is offline
Old 09-22-2007, 08:58 PM
SIRESMERPH's Avatar
darnet...now you got me thinking about if i fixed the extension tube when i did the oil change. i was messing around out of curiosity, but im more than sure thatn i put it back correctly...damn it!!!
ill be back.............
yep...seated right..whew!
SIRESMERPH is offline
hhrlover101
10-25-2013 12:38 PM
stephenm
06-25-2010 12:51 AM
HHRAZ
01-30-2008 12:59 PM
stelerz
2.2L Performance Tech
12-02-2007 09:01 PM
Jack
10-07-2006 11:12 PM
Quick Reply: Oil fill cap, a little tip
