Socket size for lugnuts?
Old 04-14-2008, 08:05 PM
Goose's Avatar
What size guys for the OEM lugnuts?
Goose
Goose is offline
Old 04-14-2008, 08:21 PM
ChevyMgr's Avatar
3/4", thin walled is best.
ChevyMgr is offline
Old 04-14-2008, 08:27 PM
an08HHR's Avatar
I have the 17" polished I have to use a deep 3/4 socket, my reg socket isn't very deep and will only catch the top part of the lug nut cap. 19 mm will also work, there are only a few thousandth diff in the two
an08HHR is offline
ChevyMgr's Avatar
Originally Posted by an08HHR
I have the 17" polished I have to use a deep socket, my reg socket will only catch the top part of the lug nut cap
Good point, deep is always better!
ChevyMgr is offline
Old 04-14-2008, 08:36 PM
Goose's Avatar
Thanks!!
Goose
Goose is offline
Old 04-14-2008, 09:46 PM
Black Rose's Avatar
I have the 16" aluminum rims and had to use a deep socket also. My standard socket wouldn't fit all the way.
I have a 4-way wrench I use to take the lugs off and to snug them up, then I use my torque wrench with the deep socket.
Black Rose is offline
Old 04-14-2008, 09:51 PM
pg318's Avatar
I'd assume it's meant to be 19mm, since the threads are M12.
pg318 is offline
Old 04-15-2008, 07:07 AM
an08HHR's Avatar
My 19mm socket measures .755 inches and my 3/4 socket (both 6pts) measures .760 inches between flats. The lug nut thread size is M12 x 1.5 . I was only answering the question as to size of socket used.
an08HHR is offline
Old 04-15-2008, 08:18 AM
Goose's Avatar
In other words, either the 19mm or 3/4 will work just fine...correct?
Goose
Goose is offline
Old 04-15-2008, 08:19 AM
ChevyMgr's Avatar
Goose
Correct.
ChevyMgr is offline
Blue Beast (aka Boydie)
03-20-2014 01:48 PM
capp002
Tires & Wheels
11-19-2012 10:17 AM
Technut
Tires & Wheels
04-05-2010 04:18 AM
One Nut
04-01-2009 07:11 PM
Quick Reply: Socket size for lugnuts?
