GM Recall Campaigns For Information & Discussion of General Motors Recalls
Ignition Switch Recall Key Question
Old 04-01-2014, 08:07 PM
DrTrapper's Avatar
I didn't want to clutter the main thread about the ignition switch recall, so I thought I would post this here. What I would like to know is since it sounds like all of us that have HHR's(I have 2 2010's) will have the ignition switch replaced(which I assume will mean getting a new key), what happens if we have an extra key? Will Chevy replace them as well? I have 2 keys for each of my cars and don't want to have to spend extra $$ to have the spare keys cut if I don't have to .
DrTrapper is offline
Old 04-01-2014, 08:45 PM
Technical Moderator
As I understand it is just a replacement no new keys needed. I know they are not going to replace every bodies door locks.
"Front Page News" is completely the wrong place to post, it goes into moderation, which means nobody sees it until a moderator moves it.
Try calling your local GM service Dept., they are the authority, not us shut ins. This website has no official connection to GM. It is a "fan" site.
Just relax, use your telephone.
donbrew is offline
Old 04-01-2014, 10:19 PM
The ignition switch is the part being replaced. Not the ignition key cylinder.
2 different parts. I would assume they will reuse the old key cylinder and you will use the original key.
Anyone can correct me if I'm wrong.
firemangeorge is online now
Old 04-01-2014, 10:25 PM
No re-keying of the vehicles will be necessary, so your current keys will not need replacing.
843de is offline
Old 04-01-2014, 10:31 PM
Hey Mike, have you got a parts diagram picture that shows the seperate parts: ignition switch/ key cylinder?
Might help some of our members understand a little better.
Old 04-02-2014, 01:14 AM
This old thread should help clear things up, the ignition switch is the part that will be replaced, the ignition lock cylinder is reused so no re-keying is necessary.
https://www.chevyhhr.net/forums/problems-service-repairs-42/ignition-cylinder-lock-20649/
Scroll down to post #2 for diagrams and instructions.
843de is offline
Old 04-02-2014, 07:10 AM
#4 is the ignition switch. #9 the ignition key cylinder.
Old 04-02-2014, 07:55 AM
Lucky's Avatar
You beat me to it. I was going to put up that same diagram.
Lucky is offline
Old 04-02-2014, 04:59 PM
Hey Everyone,
I just wanted to pop in with a reminder. If you have any questions or concerns in regard to recalls, please do not hesitate to reach out to us via private message. Thank you so much 843de and firemangeorge for the clarification and visual.
Erica Tiffany
Chevrolet Customer Care
ChevroletCustomerService is offline
Old 04-03-2014, 07:46 PM
DrTrapper's Avatar
Thanks to everyone for the answer! I was thinking it wouldn't be the key, but I wanted to make sure. Now the $64,000,000 question....when will the cylinders be in stock at the dealers? :)
Quick Reply: Ignition Switch Recall Key Question
