Front and rear engine mount torque specs
Old 10-28-2016, 06:53 PM
fonque's Avatar
Does any one have the torque specs for the front and rear engine mounts? I am doing a motor mount install this weekend, but i have yet to find a post with the torque for all 3 engine mounts listed.
Any help is very much appreciated!
fonque is offline
Old 10-28-2016, 07:04 PM
I found this one
https://www.chevyhhr.net/forums/prob...-mounts-57538/
Oldblue is offline
Old 10-28-2016, 07:14 PM
Technical Moderator
Or here, I don't think there is a difference auto/manual.
https://www.chevyhhr.net/forums/how-...e-items-54648/
Rear is the same.
donbrew is offline
Old 10-29-2016, 08:20 AM
fonque's Avatar
Thanks for the info on the front mount!
Does anyone have the torque specs for the rear mount behind the engine?
fonque is offline
Old 10-29-2016, 08:36 AM
I found Cobalt specs, 37 foot lbs for the 18 mm bolts
Oldblue is offline
Old 10-29-2016, 09:37 AM
Technical Moderator
Rear is the same.
rear is the same
donbrew is offline
Old 10-30-2016, 02:56 AM
06HHRDUDE's Avatar
Automatic:
Front Mount Bracket Bolts - 89 ft-lb AT
Front Mount - 96 ft-lb
Rear Mount - 90 ft-lb
Side Mount - 49 ft-lb
Mount Thrubolt Front - 55 ft-lb
Mount Thrubolt Rear - 89 ft-lb
Mount Thrubolt Side - 41 ft-;b
Manual:
Front Mount Bolts - 37 ft-lb
Front Mount Thrubolt - 74 ft-lb
Rear Mount to Bracket to Trans Bolt - 44 ft-lb
Rear Mount Thrubolt - 74 ft-lb
Rear Mount To Frame Bolts - 44 ft-lb
Side Mount Bolts - 33 ft-lb
Side Mount to Mid Rail Bolts - 25 ft-lbs
06HHRDUDE is offline
Old 10-30-2016, 03:45 AM
fonque's Avatar
Thanks for the list that is exactly what i needed! i got the mounts installed last night. Havent had a chance to drive it yet.
fonque is offline
imagepower
12
10-30-2015 07:50 PM
harleysshhr
08-24-2010 08:36 PM
8t7vette
08-02-2010 02:09 PM
intofocuszx3
03-18-2010 07:08 AM
Navyflyer11
08-17-2007 10:19 AM
Quick Reply: Front and rear engine mount torque specs
