please help
Please help, key struck in ignition
I have a 2007 HHR and usually every few months the 60 amp fuse blows. they ran a test everything was good nut today it did it again and after changing the fuse it would not start and I could not get the key back to take it out, my daughter did get it released by clicking something under the steering wheel. anyone have this problem?
My 2007 hhr the key is stuck in the ignition. I replaced the 60 amp fuse and it still will not move to start, anyone have this problem, if you could email me with any help I will be so thankful as I really don't know how to use this. my email is . thanks so much
Robin
Robin
To get you started read the section of the Owner manual about removing a stuck key. Online Owner Manual is available through the link in my sig.
What is the state of the battery? Is the security light on? Is the engine running? Has the ignition recall been performed?
https://www.chevyhhr.net/forums/gm-r...-status-50716/
Certain conditions are covered by an extended warranty on the shift mechanism.
Here is one link I found by typing the title of your post into the search box:
https://www.chevyhhr.net/forums/how-...uck-fix-52950/
I removed your email address from the post to protect your privacy. Use Private Messaging, it is safer.
Which 60 amp fuse?
If you mean the one near the battery in the trunk, it is dangerous, find out why it blows and get it fixed!
If you mean the power steering fuse under the hood, go to a GM dealer and have the power steering motor replaced under the Extended Warranty.
Here is a link that is a possible solution, it is now covered by another Extended Warranty.
Has the ignition recall been done?
Online Owner Manual available from a link in my sig.
2smokey
13
08-23-2012 12:18 AM
