Brake fluid/Clutch fluid flush??
Sounds interesting - keep us posted on how it works out for you. Manually changing fluid has to be one of the most boring maintenance jobs - having the flush machine handy would be a treat. :-)
You can use DOT 3, DOT 4 and DOT 5.1. Difference is in boiling and wet points.
DOT 5 is synthetic and will truly F up your brake/clutch system since it wasn't designed for it.
I'll be doing mine soon with DOT 5.1.
