Mildewed carpet: clean or replace?
Old 08-04-2015, 02:36 PM
Texana's Avatar
I left the windows on my 2011 HHR cracked open during a thunderstorm. I dried it the best I could, but it now smells as though there is something dead in my car. I checked for dead mice, and didn't find anything, so the only thing it can be is mildew.
I haven't encountered any other leaks.
I have vacuumed, used the wet vac, sprinkled baking soda, sprayed with Febreeze, cleaned with regular rug cleaner, and it still smells horrible. I'm embarrassed to drive with my windows done because I'm afraid someone I pass will smell it.
Are there special cleaning products for stubborn mildew in carpet or should I just take it out and replace it? Is replacing auto carpet something an amateur can do, or will I need to take it to a body shop?
Texana is offline
Old 08-04-2015, 03:12 PM
Technical Moderator
Replacing it involves removing the seats and interior panels. Not difficult, but a huge PIA. Plan on most of a days work.
The carpet is one piece and has a thick semi rigid backing.
donbrew is offline
Old 08-05-2015, 03:41 AM
You might want to check with your local Fire & Water damage remediation companies, or someone like ServPro.
There's probably a way to clean the carpet in situ and get rid of the mold/mildew which not only stinks, but certain strains of mold can cause you to become quite ill.
And as Don stated, the last resort is installing new carpeting, but on a 1-10 PITA scale, it's a good solid 9.
Oh, also check with your insurance company, this might be covered under the Comprehensive section of your policy, just be mindful of your deductible.
843de is offline
Old 08-05-2015, 11:59 AM
Texana's Avatar
Thank you both for your answers.
I hadn't thought of taking it to a profession cleaning service. I did check with detail shops, but they didn't inspire a lot of confidence in me.
Texana is offline
Old 08-05-2015, 02:15 PM
Trust me. The only way to get it completely dry is to remove the carpet.
Been there, done that on other vehicles.
firemangeorge is online now
Old 08-05-2015, 03:01 PM
Texana's Avatar
Do you mean to take it out and clean it, or do you mean replace it?
I did think it would be less hassle to replace the carpet, but I'm having a hard time finding replacement carpet, even at some the websites recommended here.
Texana is offline
Old 08-05-2015, 06:00 PM
Technical Moderator
You will only find new carpet from GM, used maybe from a junkyard.
The fairly thick padding is part of the carpet. The mildew is most likely growing between the metal and the pad.
This site does not recommend any sources. There are a couple of paid advertisements, and Google ads.
donbrew is offline
Old 08-05-2015, 08:03 PM
Take it out and clean it, OR, if it's not salvageable, then replace it. Either way, you need to pull the old carpet out.
A wet/dry vac will not pull the moisture out of the padding. Last carpet I pulled out was on my 17 year old truck. Water had worked it's way all up under the front seats from a rear window leak.
Mine didn't have much mildew but I cleaned the carpet with some carpet cleaner I got at Wally World. Some brand of spray foam stuff.
Cleaned the bare truck floor with a water/clorox mix. Let the carpet and padding dry in the sun for 2 days.
Carpet looked almost new again, so I reinstalled it.
Old 08-06-2015, 08:07 AM
Send a PM to Wreck, he is parting out his HHR parts car, he may have a carpet
Oldblue is offline
EMBROWN
07-15-2013 08:25 AM
Lone Ranger
06-29-2007 09:12 PM
RICANBABY
05-27-2007 03:53 PM
coachpete
08-25-2006 05:34 PM
Quick Reply: Mildewed carpet: clean or replace?
