Rear brakes
Old 05-11-2016, 01:59 PM
ONELON : "I understand you know that the friction between the pads and the drums will wear the pads down and free the wheels after driving it a few miles." yes it will - and you will end up with overheated drums, possibly warping them if not catching something on fire.
If it is true that your mechanic said: " As far as tightening the brakes too much, he says it's fine. As long as you can move the wheel with your hands they're good. " - then you really need to find another mechanic.
I'm out of this one.
whopper is offline
Old 05-11-2016, 07:45 PM
alexrckid's Avatar
sounds like that action would make the brakes a tad bit tooooo tight. and, shoes, not pads....
alexrckid is offline
Old 05-12-2016, 01:00 AM
onelon's Avatar
Looks like this thread got a little out of control....
Anyway, I got home after school and hoisted the car up. The rear wheels gave me a good 8 or 10 spins, both sides. Apparently the measurement of "too much" or "too tight" varies a between individuals...
onelon is offline
Old 05-12-2016, 07:28 AM
8 to 10 spins it a bit much, it should be 3 or 4!
Oldblue is offline
Old 05-12-2016, 07:58 AM
Technical Moderator
One of the parts of the procedure that is often forgotten is the centering of the shoes.
After you think you got them adjusted you step on the brake pedal to center the shoes, then check the adjustment again. Usually they will be looser then.
donbrew is offline
Old 05-12-2016, 11:41 AM
onelon's Avatar
I can live with that. Before working on the brakes it would give infinite spins.
onelon is offline
Old 05-12-2016, 11:44 AM
onelon's Avatar
I did do it. I stepped on the breaks to center them like the video shows. The I spinned the wheels and got 8 spins
onelon is offline
Old 05-22-2016, 10:19 AM
dr_fosg8's Avatar
I think it is safe to say that the rear brake system on the HHR is poo. I have stopped bothering to adjust mine about 50,000 miles ago and have had no problems stopping at all. Even when properly adjusted the just dont add much to the system.
dr_fosg8 is offline
Old 05-22-2016, 11:28 AM
Technical Moderator
But... poorly adjusted they make the fronts do more than they are designed for=failure.
The number one cause of "warped" rotors.
donbrew is offline
Old 05-22-2016, 04:34 PM
And rear end collisions!! Those rear brakes need to be adjusted correctly!!
The rear brake design isn't poo!!! It's the auto adjust mechanism not set or lubricated correctly!!
Oldblue is offline
Quick Reply: Rear brakes
