Catalytic converter clogged?
Old 07-01-2015, 05:18 PM
08ShadowHHR's Avatar
Did a search and didn't find info.
My exhaust note suddenly got quieter. Almost seems to wheeze a little. Also seems a tad down on power. Check engine light NOT on, no other warnings of any kind.
2.2 auto with 160,000 miles.
I'm wondering if the cat is clogged or choked.
08ShadowHHR is offline
Old 07-01-2015, 05:29 PM
It is very possible, especially if there is a possible coolant leak into the combustion chambers, antifreeze will clog up your catalytic converter
Oldblue is offline
Old 07-01-2015, 06:16 PM
Technical Moderator
IF the cat is clogged you would get a P0420 code(period). It's the law.
I would however look at the flex pipe, if the sound has changed.
donbrew is offline
Old 07-02-2015, 01:10 PM
Cool, thanks. It's kind of what I thought. I was a bit surprised I didn't get the code warning. I'll have get a closer look.
Old 07-02-2015, 02:48 PM
You can just replace the flex pipe or the complete pipe and cat assembly
Oldblue is offline
jstadtjr
07-11-2015 10:04 AM
donbrew
12-18-2014 08:48 PM
West09LT
Maintenance and Upkeep
09-25-2013 05:50 PM
LolaIsMyHHR
03-29-2011 10:37 PM
DjLBM
02-22-2011 01:49 PM
Quick Reply: Catalytic converter clogged?
