What tempeture does the HHR SS run at "coolent"
Old 08-29-2010, 12:51 PM
camaro98z28's Avatar
Question What tempeture does the HHR SS run at "coolent"
Depending on the day, the info tempeture will read between 208 and 221deg here in AZ. The gauge on the cluster reads lower than halfway. Which one to read and what are the temp range for the HHR? This is summer time driving with 107 to 114 deg outside. Thanks
camaro98z28 is offline
Old 08-29-2010, 03:35 PM
2010 SS temps
Last week we had temps in the high 90's with high humidity here in Alabama.Mine was showing 187-193.Never hit 200 or higher in 8 months since new.
firemangeorge is offline
Old 08-29-2010, 04:15 PM
Don06's Avatar
Mine is always under 200 but I'm not in such high ambient temperatures. Does it run cooler when it's cooler outside? Does the stage 1 kit use a higher temp thermostat?
Don06 is offline
Old 08-29-2010, 06:55 PM
Laco's Avatar
In moderate or cool weather mine runs between 185 and 194 or so, in hot weather higher. In really hot weather, 104 plus, it runs above 200, sometimes as high as 215, but cools quickly as I slow down. The electric fan is pretty effective, even in 100 degree plus weather, it can idle for long periods of time and stay right around 200, of course with the AC running. AC in the HHR is very effective.
Laco is offline
Old 08-29-2010, 07:09 PM
09 Silver Bullett's Avatar
The stage 1 kit does not come with a different thermostat. A different one is not needed either.
09 Silver Bullett is offline
Old 08-29-2010, 07:39 PM
pitbull76's Avatar
camaro, Mine often runs in the same range as yours. It is usually in the low 200's but sometimes it gets into the teens. I just saw 219 today while waiting to park for a ballgame.
pitbull76 is offline
Old 08-30-2010, 06:53 AM
peevlos's Avatar
If I'm sitting at a light on a 90+ degree day I see 214-ish, fan kicks on drops to 204. Same day on the highway I'm generally running 192-198 or so
peevlos is offline
Old 08-30-2010, 09:39 AM
This morning it didnt go above 205. LOL
which one is more accurate, the Temp cluster gauge or digital read out.
Old 08-30-2010, 09:11 PM
Gas Man's Avatar
I will have to pay more attention but I don't think I've ever seen over 199*
Gas Man is offline
geg
11-25-2020 12:52 AM
kayakjax
21
09-29-2011 09:11 PM
da_loca
12-08-2006 12:34 AM
Lee In Calfi
07-19-2006 07:22 AM
Quick Reply: What tempeture does the HHR SS run at "coolent"
