Power Mirror Problems
Old 01-15-2013, 02:49 PM
edgardop73's Avatar
Unhappy Power Mirror Problems
I have read several forums about Power Mirror issues but I havent found a solution for mine. My son spilled soda on the switch and it would only work on the passengers side on the up position. I got a replacement switch and had the same happen with the new switch. Checked fuse #21 and its ok. Any reasoning on what could be wrong? Switch worked fine before the spill.
edgardop73 is offline
Old 01-15-2013, 02:57 PM
ChevyMgr's Avatar
Liquid in the switch connector?
ChevyMgr is offline
Old 01-15-2013, 03:02 PM
edgardop73's Avatar
It happened a while ago, switch connector is dry
Old 01-15-2013, 04:38 PM
ChevyMgr's Avatar
Probably a bad mirror motor and the switch wasn't at fault to begin with then.
ChevyMgr is offline
Old 01-15-2013, 06:29 PM
A Crazy Canuck's Avatar
Is it possible to short out a relay? Is there one that controls the power mirrors?
A Crazy Canuck is offline
Old 01-16-2013, 10:53 AM
IgottaWoody's Avatar
may be dry , but soda is sticky sweet and will coat the terminals...get some cleaner on them
IgottaWoody is offline
Old 01-16-2013, 04:18 PM
Technical Moderator
X2
My 2008 sometimes worked on both sides when I got it, then never worked again. I am the only driver, so I never cared enough to check it out. While I was replacing the left door speaker, I tried to unplug the mirror switch but gave up because it is a giant PITA.
donbrew is offline
Old 01-17-2013, 02:33 PM
edgardop73's Avatar
Cleaned the switch, used an eraser on the contacts, and it started working again. Thanks for your ideas guys. I sent back the switch I ordered thru ebay today.
Old 01-17-2013, 04:19 PM
ChevyMgr's Avatar
Thanks, I should have said that too.
ChevyMgr is offline
Old 01-18-2013, 10:22 AM
bigboss2010
03-06-2014 03:55 PM
slinger569
10-28-2013 10:55 AM
Dunny
05-12-2013 10:38 AM
Rod Run
01-05-2012 10:17 PM
Kicker|MyU
03-13-2008 07:01 PM
Quick Reply: Power Mirror Problems
