Check Engine light on - no codes
Old 09-12-2010, 12:57 PM
Wolfie's Avatar
Hi Guys,
Lately, I have some problemos with my check engine light ...
I've had a few times the code for small Evap leak, so I replaced the gas cap.
After replacing the gas cap, check engine light is on again ... checked for codes again and although check engine light is on, I have no codes - go figure
Any suggestions pls ???
Wolfie is offline
Old 09-16-2010, 05:36 AM
ret
ret's Avatar
Remove the battery cable to reset system.
Use a different code tester.
ret is offline
Old 10-06-2010, 09:24 AM
Thylacine's Avatar
My light the check engine came on, and I could not figure it out. While chasing everything down I found the passenger rear turn signal was burnt out. I replaced that and thought I would take it into the mechanic to find the gremlin. I started it up and the check engine light went off.
Thylacine is offline
Old 11-09-2011, 11:13 AM
Thylacine's Avatar
Originally Posted by Wolfie
Hi Guys,
I now have this problem too.
Old 11-09-2011, 11:33 AM
LawDog88's Avatar
It sounds like you need to take it to AutoZone and have them pull the code. No offense, but they have good code readers.. Not saying yours isn't. But I bet they can find a code, even if yours can not..
LawDog88 is offline
Old 11-09-2011, 05:04 PM
BlackknighT's Avatar
You have to make sure your code reader has CAN capability.... Some readers are just ODB2 while others are ODB2 & CAN protocol.
BlackknighT is offline
Old 11-11-2011, 03:59 PM
@Thylacine, how are things going with your situation with your HHR? Did you take the advice of Officer1151?
ChevroletCustomerService is offline
Old 11-11-2011, 11:21 PM
KissMy08SS's Avatar
I wish my CEL would come on.....
Mine is running bad....but the CEL just will not come on. Dealer said they won't look at it anymore because they can't diagnose the problem if the CEL isn't coming on...
KissMy08SS is offline
Old 11-28-2011, 09:06 AM
Thylacine's Avatar
I took it in, they could not pull a code. After they tried it went off for about 15 minutes then came back on. Of course it will be on all winter, just when you really want to use the remote start. I am tired of wasting time on this problem.
Old 01-10-2012, 04:55 PM
speedwagen's Avatar
I have just had a CEL occur on my HHR, and when I looked at my owners manual, I was surprised to see that a TPS problem will flash a CEL,then turn to steady.
speedwagen is offline
purple people eater
09-17-2016 01:07 PM
LadyBee
06-20-2014 11:48 AM
flooprigger
08-04-2013 08:58 AM
jmpnjoe86
03-10-2013 06:13 PM
camaro98z28
04-13-2010 10:32 PM
Quick Reply: Check Engine light on - no codes
