Suspension Noise
Old 05-12-2011, 12:42 AM
fanbelt.1's Avatar
Suspension Noise
My '08 SS has developed some suspension noises that are causing me concern:
1) The car has a serious front-end rattle that developed about 4 weeks after I took delivery of the car when new.
It started out as a rattle that sounded like a rubber ball rattling around inside a metal coffee can when going over uneven or broken pavement....most noticeable at low speeds. Lately it's gotten worse, and it's now noticeable even on relatively smooth surfaces. Any suspension movement now seems to cause it. So far the dealer claims not to hear it.
2) When the outside temp falls below 45 degrees, there is a noticeable squeak at both front corners, coinciding with any suspension travel. This happens when drivibng the car cold after leaving it outsiode overnight (if I had a garage, I'd be storing it there). The colder the weather, the worse the squeaks. They go away after a couple of minutes' driving as things start to warm up. Last winter I also started noticing this condition at both rear corners as well.....but not as bad as the problem up front.
Has anyone else also experienced these problems, or knows what causes them? Next time I go to my dealer for service, I'd like to be armed with as much info as possible about these problems.
fanbelt.1 is offline
Old 05-12-2011, 12:56 AM
Welcome and Greetings! Here is a link on the infamous HHR front end clunk/rattle and the most common cures.
https://www.chevyhhr.net/forums/show...ght=sway+links
And here's a thread on suspension squeaks in cold weather, hope they help answer some of your questions.
https://www.chevyhhr.net/forums/show...pension+noises
843de is offline
Old 05-12-2011, 05:35 AM
Mike. Did you notice that fanbelt has been a member here since 2008? Silent for 3 years then.........
firemangeorge is online now
Old 05-12-2011, 07:15 AM
It just takes a while for some folks to warm up
SS fan is offline
Old 08-28-2012, 07:54 AM
lainix's Avatar
I have the same issue on my 08 LT
I was told the bushings in my struts are worn out and need replaced. not a big issue if you are on smooth road, usually what a dealer will test on, but as soon as the road is bumpy or uneven you will tell.
lainix is offline
Old 09-03-2012, 02:13 PM
flmj's Avatar
My noisy suspension problem was a motor mount according to the dealer.
It was replaced under the warranty, but I notice that I'm getting the noise
again and the warranty is gone.
flmj is offline
Old 09-04-2012, 01:08 PM
flmj, when did you have the mounts replaced? There should have been a parts and labor warrant which would have been for 12 months or 12,000 miles whichever happened first if they used genuine GM parts.
ChevroletCustomerService is offline
Old 11-03-2013, 06:32 AM
CHEVYMAN 65's Avatar
Try this first
I have an 09 LT.Have had a noise up front for a year now,Its a certified car so my dealer changed everything -struts -sway bar links -steering column.Still have noise.So last week I replaced sway bar bushings myself.Using G.M. parts I bought from E-bay for about $13 bucks.I greased the new bushings before installing them.The old bushings showed no signs of wear at all.The noise is completely gone and I haven't been able to duplicate it again.So give it a try.
CHEVYMAN 65 is offline
Old 11-03-2013, 07:53 AM
Guest
hozer's Avatar
Hello fellow local NJ HHR owner.I get that squeak when it is cold outside also.It happens when I go over "dips" in the road but does not happen over bumps.Can't tell if it is from the front or rear.As you the colder it gets the more noticeable the sound is.Goes away when driven a little bit and never happens when it is warm outside.I just ignore it for the most part.Car drives fine.
hozer is offline
Old 11-03-2013, 08:20 AM
Hozer. Fwiw. You're answering a 3 year old post and fanbelt.1 hasn't been on this site in over 1 year.
Quick Reply: Suspension Noise
