Suspension Noise
Hello fellow local NJ HHR owner.I get that squeak when it is cold outside also.It happens when I go over "dips" in the road but does not happen over bumps.Can't tell if it is from the front or rear.As you the colder it gets the more noticeable the sound is.Goes away when driven a little bit and never happens when it is warm outside.I just ignore it for the most part.Car drives fine.
And Hozer is a Canadian expression, are you sure youre allowed to use it?
