Racing Discussion Race Track Victories - DRIVE RESPONSIBLY
1/4 times?
Old 04-17-2006, 11:44 PM
cowboybornlate's Avatar
That's funny right dere, an 8000 pound HHR.... that sounds more like a Hummer than an HHR.... I was thinking somewhere just over 3000 pounds is what I heard...
CBL
cowboybornlate is offline
Old 06-19-2006, 05:38 PM
CooperDesigns's Avatar
Well here is a little real life 1/8th mile and 1/4 mile times from this fathers day weekend. Mine is a 2.4l automatic that is bone stock except for synthetic oil and Bosch 2 plugs.
Best times (not all in the same runs)
1/4 mile ET 16.79 @ 82 mph
1/8 mile ET 10.89 @ 70 mph
60 foot time 2.434
MPH 83
Reaction time .515
My car was so 1/4 mile consistent it was sick. I ran 22 consecutive test & tune runs and all varied between 16.80 - 16.83 and all were 81 mph. My 60 ft. times however were all over the map in the beginning ranging from 2.75 - 2.43 which hurt 1/8th mile consistency.
The weather was hot and muggy which is why the car was down a couple mph. It was 90 - 95 all day with 90% humidity (thick).
In the beginning I started out with 20 psi in the front and 40 psi in the rear (stock 17" wheels). I had too much traction and the motor was getting bogged down from lack of hampsters on the hampster wheel, so I went to 24 psi then to 30. I stayed as 30 the rest of the day and it was hooked up perfect without dropping rpm's at launch and without barking the tires. I torque brake launched at 2500 rpm's. The converter was too engaged at 3000 to make the launch effective.
I am lowering it this week which should help a little and then I am going to play with intake options. I will try to keep this page updated as i go.
The great part of this adventure is that I won Sportsmen (Trophy) bracket 2 out of 47 cars which I was estatic about. All I had to do was react lower than .600 and it was in the bag every single run. I dialed in at 16.80 and never changed the shoe polish all day. I made the finals in top eliminator but red lighted trying to out tree the guy with the 8.13 second Camaro.
There is no doubt that when the humidity gets down around 65% the car will run 16.7's all day long. I am a data freak and a little side note is that everyone is stuck on these motors performing best between 180 - 190 degrees (coolant temp). I have not dyno'd yet (next week) but ET wise my worst times were at these temps. Every 16.83 and lower run was when the coolant temp was reading 200 or above. The 16.7 run was 214 at the time I staged.
Matt
CooperDesigns is offline
Old 06-19-2006, 05:44 PM
Matt, great first post!
I'm really looking forward to see your progress in getting your wagon a little more giddy-up!
Maybe a few ideas I can steal.....I mean use!
Welcome to the forum.
GDZHHR is offline
Old 06-19-2006, 05:53 PM
SoCalHHR's Avatar
Welcome Matt! Good post with a lot of important data. You're spot-on about the 2.4L temps; it likes to run "hot." Some of our dyno tests had it running up to 228, but it is quick to recover and makes good power there.
What fuel are you running? rying any octane boosters? The 2.4L responds well to Shell V-Power and 108+ - might want to give it a try.
I look forward to reading your future posts!
SoCalHHR is offline
Old 06-19-2006, 08:05 PM
Thanks guys I appreciate the welcome. I forgot to mention that I am about 500 ft. above sea level just so you can compare apples to apples. I also just let the car shift itself however I am going to manually shift it this weekend for comparison. Also those with 16" wheels should see better 60ft. times as the additional sidewall works in your favor.
87 octane from Speedy Q w/ zero additives. I have my own theory but I will wait til next week when I get it on the dyno to share it.
I am a piston, crankshaft and induction engineer. I build A Fuel motors and am a cylinder head specialist and left side motor wrench on the Bowen Racing A Fuel dragster. I have been a die hard aircooled VW guy forever and bought this to burn miles (23,000 in 3 1/2 months) as I travel to Canada a lot for business.
I am going to test different intake configurations (even was given one of those Tornado atomisers to test), then a few exhaust combos then work with the ECU and go through it all over again. I will try to add as much as I can and will add pics. This will not turn out to be a full drag car but I am really considering Bogart wheels and slicks for no other reason than because. I want to see how consistent the car stays with little mods.
Nice forum!
Old 06-20-2006, 12:14 PM
  #26
Bowtie388SBC's Avatar
Welcome!!!
Hi Matt,,,,Welcome to the forum and thank you for the info on your weekend blast down the track....2nd place is'nt to shabby with the HHR....You must of been as consistant with the tree as the HHR was down the track......Hope to read more.
Bowtie388SBC is offline
Old 06-27-2006, 07:58 PM
  #27
Alzonie's Avatar
Originally Posted by teknobunie
I was told the HHR weighs almost 4 tons.......can anyone verify that???????
With my Wife in the driver's seat maybe !!
Alzonie is offline
Old 07-05-2006, 08:53 AM
  #28
SCOOT's Avatar
Hey Matt... Welcome.
Are you doing all your test-n-tunes @ Lapeer Dragway? Lemme know- I'll try and make it up there someday. Wouldn't mind running my bike (slightly modded '95 CBR 600) just for kicks! That is... I think they let bikes run there. Think it's like $20 to do as many runs as you want, right (first come, first serve)? I'd prolly run early due to the bike generally running hot.
Lemme know.
Thx.
SCOOT is offline
Wolfblitz
Racing Discussion
10
09-25-2012 11:59 PM
dsmisfits
01-11-2011 03:37 PM
corvairman
10-02-2010 02:13 PM
krh0003
2.0L Performance Tech
17
05-16-2010 07:27 PM
txbass06
10-27-2009 08:14 PM
Quick Reply: 1/4 times?
