Cooling fan start UP temp?
Coming from a Cobalt SS to a 2.4HHR I can tell you... this thing runs HOT. If I'm just sitting idling the coolant temp will get above 220 pretty easily.
Honestly I don't see it as a big problem... the car seems to run just fine either way.
If you are that concerned, you can command the fans on at a lower temp through HPTuners.
If your A/C was off that is understandable. The fans weren't running and no air was moving thru the radiator/coolant.
