XM radio
Old 12-25-2007, 01:12 PM
ClassicWalt's Avatar
XM radio
I have the cat button on my radio but i do not have the antenna on the rear roof of the vehicle,do i need an adapter to recieve xm signals so i can subscribe?
ClassicWalt is offline
Old 12-25-2007, 08:58 PM
JayKWills's Avatar
what happens when you push the cat button?
JayKWills is offline
Old 12-25-2007, 09:40 PM
candid228's Avatar
I to had the Cat button, but that does not mean you have xm, if you push it and it gives you channels then it is there. I went to the dealer and they had no idea and said i had sat rdo. I called xm and they walked me thru to find out if I have it. I didnt. After market......
Charlie
candid228 is offline
Old 01-08-2008, 11:26 PM
Smoke Wagon's Avatar
get ahold of XM...I am sure you can add their car installation kit to your car, and get XM.
go to their website, and click on ACCESSORIES. It's a flash-type website, so I cant link the part, but click and find the car accessories...they sell an antenna for $29.99
http://www.xmradio.com/shop/index.xmc
You'll have to ask the stereo gurus how that hooks to your factory radio.
Most local stereo shops would know because they do this sort of thing for a living. Not that they have to install it for you...but they should know if all you need is a XM antenna to get your XM-ready factory head unit to receive a signal.
Smoke Wagon is offline
Old 01-09-2008, 06:48 AM
hhrcrafty's Avatar
The stock radio doesn't have an XM receiver, only an interface to the optional XM receiver box. You can't just hook an antenna to it and go.
hhrcrafty is offline
Old 01-09-2008, 07:47 AM
CrashMan82's Avatar
No antenna = no reciever = no wiring harness to the rear where the factory installs.
Best bet is aftermarket, there's a GM-LAN4 XM direct kit, or you get the OE kit for about the same price. The XM direct should be easier to install since you don't have to run the harness to the back and drill the roof to mount the stock antenna. Both run about $300 plus install.
CrashMan82 is offline
Krusty
06-09-2012 02:45 PM
capp002
10-18-2011 02:24 PM
SargeRN
10-05-2011 08:21 AM
Sno White
"How To" Tutorial Library
11
08-26-2009 05:48 PM
KY Dave
07-26-2006 04:27 PM
Quick Reply: XM radio
