Turn Signal Lever no longer cancels automatically
Old 12-15-2008, 04:03 PM
alien_sporez's Avatar
Of course, since I just rolled over 36K miles, now this happens.
Anyways, my turn signal lever isn't cancelling automatically after I complete a turn. Right now only right turns don't cancel.
Anyone else have this problem?
Also, how do I repair it (part numbers would be helpful)?
alien_sporez is offline
Old 12-15-2008, 04:11 PM
SindyDix's Avatar
I've had this problem for a very long time now. I never took it in to be fixed. It's just a habit now to return the lever to the neutral position.
Here is the thread on it. Perhaps ChevyMgr has some insight in this from when this was first posted way back when.
https://www.chevyhhr.net/forums/show...ighlight=lever
SindyDix is offline
Old 12-15-2008, 04:18 PM
Yes, I originally did a search and found that thread. But since it was from 2 yrs ago, and nothing seemed to become of it, I thought I'd start a new thread to get some new insights.
Old 12-15-2008, 04:20 PM
pitbull76's Avatar
Might just be an adjustment. I had to take mine back after the steering column was replaced since it did not reliably cancel the turn signals. Dealer said it was just a basic adjustment.
pitbull76 is offline
Old 12-15-2008, 04:26 PM
Possibly the multi-function switch. Costs around $150 to fix.
Old 12-15-2008, 04:51 PM
Turn Signal Multifunction Switch Replacement
Removal Procedure
Remove the instrument panel cluster trim plate bezel. Refer to Instrument Panel Cluster Trim Plate Bezel Replacement .
Remove the lower steering column trim cover bolts and remove the upper steering column trim cover. Refer to Steering Column Trim Covers Replacement Steering Column Trim Covers Replacement .
Disconnect the turn signal multifunction switch electrical connectors.
Position the left lower steering column trim cover out of the way,
Depress the switch locking tabs and remove the turn signal multifunction switch (1).
Old 12-15-2008, 05:21 PM
MGMsHHR's Avatar
I had the same problem about 3 weeks ago. But mine would not cancel from left turn all the time.......i out of ten times it would not cancel. Dealer replaced the turn signal multifuntion switch and all is fine. Mine was under warranty with only 14000 on it but its only 8 months old.
MGMsHHR is offline
Old 12-16-2008, 05:46 AM
trfindley's Avatar
Mine started doing this at around 36,000 miles 1 month ago. It doesn't cancel to the right. I found that putting a little more effort in straightening the wheel would cancel it. I am reluctant to squirt WD-40 into it. Maybe rub some white lithium grease in there with a Q-tip?
trfindley is offline
Old 01-18-2010, 10:11 AM
imredbeard's Avatar
My 08 panel is at the dealer for this right now, they can't reproduce the problem. It looks like I'm going to have to drive an hour to show them it doesn't always cancel. I explained a right turn followed by a left will do it every time. With only 1200 miles left on the bumper to bumper I'm not taking it back until its fixed.
imredbeard is offline
Old 01-19-2010, 06:33 PM
MGMsHHR's Avatar
mine has been replaced twice. once at about 15000 for a intermittent left turn cancel that we are talking about. and the second time the manual headlights would not work. i went through a construction zone and you are supposed to turn headlights on, well when i turn them on they went out and the police officer in front of me had a talk about that. i won the argument by showing him the swicth was in the on position and the lights were not on. he said to get it fixed and let me go with a verbal warning.
MGMsHHR is offline
Farmers Daughter
03-31-2014 06:09 PM
HokieHHR
12-30-2013 10:18 PM
SindyDix
01-02-2012 06:14 PM
RkyMtnHHR
11-20-2009 08:15 PM
1Panel2NV
15
06-19-2008 03:15 PM
Quick Reply: Turn Signal Lever no longer cancels automatically
