Cooling Fan won't run
Old 07-02-2009, 12:11 AM
HHR Rock's's Avatar
The Cooling fan won't come on, burned up my a/c compressor. This fan should run when the a/c is running. Does anyone know where the sencor is for this fan, I don't have a repair manual. Can anyone help me with this problem.
HHR Rock's is offline
Old 07-02-2009, 06:42 AM
Dirtsurfer's Avatar
Did you check the fuse?
Dirtsurfer is offline
Old 07-02-2009, 06:52 AM
I had to replace the fan control module on the wifes 03 Mazda. It was located near the radiator.
Old 07-02-2009, 08:00 AM
Cooling fan fuse is #40 in the underhood electrical center and the relay is #50. I would start there with a test lamp.
Old 07-02-2009, 08:09 AM
HHR Rock's's Avatar
I checked the fuses and the fan relay both are good.
Old 07-02-2009, 08:32 AM
oneton's Avatar
Can you make the fan run ? Find the ter. that turns on the fan from the fan relay. make a jumper and put power to that ter. with relay removed to see if the fan motor will run. If it does then it's not the fan motor. I find it hard to think that the fan not working will burn up the A/C comp. If the fan did not go on the the High side press will go up and the high press switch will turn off the comp.
Is your car overheating or running hotter then it use to? If you let the car idle will fan come on, it will take some time for it to come on like 15-20 min. if outside air temp is not to high.
oneton is offline
Old 07-02-2009, 08:45 AM
HHR Rock's's Avatar
Jumped the fan can have it come on, I was told the if the fan does not come on it could freeze the compressor.
Patr
07-02-2022 06:50 AM
DANNY HUNTER
06-17-2019 10:46 AM
jmm121783
07-18-2014 10:17 PM
ltishea
06-14-2012 09:46 AM
Schennatirol
08-13-2010 11:54 AM
Quick Reply: Cooling Fan won't run
