timing chain replacement
Old 07-11-2012, 07:45 PM
dnutbrown's Avatar
HI,
I am getting set to do a timing chain replacement on my 2006 hhr 2.4.
403,000km or just a bit over 250,000miles. Can this be done with the engine in the car or do I have to pull the motor. I do have a 2 post lift in the garage so either is possible but I prefer not to pull the motor unless I have to do more such as crank bearings.(hoping not to go that deep as its not burning a drop of oil yet between changes.
Has anyone ever heard of having to change the balance shaft chain, or do you think its safe to leave as is.
Thanks
Dale
dnutbrown is offline
Old 07-11-2012, 08:20 PM
wmsburghhr's Avatar
This is from a Cobalt site and maybe some help to you. http://www.yourcobalt.com/forums/ins...ing-chain.html
wmsburghhr is offline
Old 07-11-2012, 09:04 PM
rpt ccss3's Avatar
You don't have to drop the engine but you need to lower it. Which it does make the job harder if you leave it in just because the lack of room. Change all changes and guides and etc . Do it right the first time!
Takes care
rpt ccss3 is offline
Old 07-13-2012, 01:05 PM
Originally Posted by dnutbrown
HI,
Thanks
Dale
I hope things are going smoothly as you are doing this to your HHR. This seems like a pretty touchy project. I wish you the best as you do the change. I look forward to any updates or pictures you would like to share.
Old 08-12-2012, 05:54 PM
dnutbrown's Avatar
Still have not done it. But I just picked up a replacement motor to swap in soon as I get a chance. Picked up a 2.4 le5 from another 2006 with 65,000 km or 40k miles for $400. Should get me and the car well up past 500,000 km or 600,000.
Dale
Old 08-13-2012, 10:48 AM
prod's Avatar
Holy smackers, thats getting up there. Ive heard the tensioner and guides usually go before the chain.
prod is offline
prod
"How To" Tutorial Library
164
07-12-2018 08:20 PM
RRAFS
01-14-2015 08:47 AM
reelescape
Maintenance and Upkeep
06-03-2014 05:46 PM
fastsuv
04-04-2014 05:58 PM
Grizzly old man
16
10-29-2013 09:01 PM
Quick Reply: timing chain replacement
