Tire Pressure Monitor Strange
Old 05-28-2015, 06:23 PM
chuckbear's Avatar
Tire pressure sensors are acting strange. The front right was reading 30 PSI and then suddenly reads 13 PSI but the tire looks fine. Left rear also reads low at 25 PSI and low tire pressure warning comes on but tire pressure with a gauge shows 30 PSI. Can these be adjusted or do they need to be replaced? Chuck
chuckbear is offline
Old 05-28-2015, 06:39 PM
Technical Moderator
If they are bad replacing is the only option, there is no replacing just the battery or adjustments.
donbrew is offline
Sandhog
11-17-2021 08:03 AM
racer-ray
Tires & Wheels
52
11-29-2013 08:40 PM
Janny May
09-06-2010 10:23 AM
TomR_here
Tires & Wheels
10
07-27-2010 07:37 PM
bad03xtreme
07-29-2009 01:49 PM
Quick Reply: Tire Pressure Monitor Strange
