Adding radio buttons on steering wheel
Old May 7, 2006 | 07:53 PM
steinywihhr's Avatar
I just went to my dealership and purchased 3 items.
1. wiring harness
2. switch assembly
3. switch cover
All for less than $65.00
I removed the horn/airbag replaced the harness and installed the switches in less than 10 min.
The only tricky part was removing the horn which I did with a 6” allen wrench that you slide through the two holes in the rear cover of the steering wheel.
Easy mod, love the mute button.
Old May 7, 2006 | 08:01 PM
BlackHHR's Avatar
Thats a sweet deal.
Good thing you didn't set off the air bag.LOL.
MikeX's Avatar
Pics?
Old May 7, 2006 | 08:34 PM
jaysz2893's Avatar
no reprogrammong of the computer?? It was one option i wanted, but could not wait for them to find the car with exact options. Good Job , and thanks for the info!
Old May 7, 2006 | 08:42 PM
courthousedeb's Avatar
Great idea...mine doesn't have that either. Sent this post to dealer to see what they would charge to do this as I worry about setting off the airbag.
Old May 7, 2006 | 10:33 PM
Will post pics soon!
no reprograming needed
Airbag not an issue(remove positive cable from the battery) I didn't and it went great. I did it in the dealer lot in less than 10 min
[update from Moderators: removing the Positive cable from the battery is a DANGEROUS thing to do (as if you short out the + terminal to ground, you can cause a major short/battery explosion)- when disconnecting the battery ALWAYS disconnect the NEGATIVE post first.]
Old May 8, 2006 | 04:03 AM
jaysz2893's Avatar
i have taken the air bags out of a few car withthe battery hoooked up. There are no sensors on the steering wheel, and you are usually safe. That being said, i am gonna disconnect the battery on the HHR.. LOL
Old May 8, 2006 | 07:34 AM
HHRBruce's Avatar
Price is right on that! Thanks for the info.
Old May 8, 2006 | 08:48 AM
GM Part #'s
call Part # cost
002 15244413 $33.75
003 15234337 $20.31
007 15234343 $12.90
Hope this helps
Old May 8, 2006 | 08:54 AM
adamlowery's Avatar
I looked into this as well. Glad you actually found something though. I found the everything i needed online, but I couldnt get the horn cover off to actually get to anything. Can't wait for the howto/pics.
