ADM Performance Stage 2 tune!!!!!
Old Oct 7, 2008 | 04:31 PM
  #31
XXL's Avatar
XXL
Originally Posted by DrLoch
Where you going to put the pump?
See post #21
Old Oct 7, 2008 | 07:16 PM
  #32
405HP_Z06's Avatar
Originally Posted by XXL
I just ordered the Snow 20010 with boost controller and a few other assorted accessories... about $520 landed. I also got a weld-in bung (waiting for the jokes) for my "maybe I'll see one soon" IC hard pipes to pretty up the install. I spoke with Greg, who recommended just plumbing it into the stock washer fluid reservoir... the blue stuff is generally a 70/30 mix of water and alcohol, and if I feel like it, I can toss in their "boost juice," which is about 50/50 mix and just have an expensive windshield washer fluid to boot (about $7/gallon). I'll start with straight washer fluid for now...
Let us know how it turns out.
Old Oct 8, 2008 | 05:45 PM
  #33
rommer's Avatar
Andy
What do you recommend as an after market clutch for this car?
Definitely going to need one.
Old Oct 8, 2008 | 05:52 PM
  #34
gcsd3742's Avatar
here's your answer: Clutchmasters already has a setup for it.
https://www.chevyhhr.net/forums/2-0l-performance-tech-46/2-0-street-ecotec-goes-10-58-et-%40-139-mph-18759/
Old Oct 8, 2008 | 06:40 PM
  #35
rommer's Avatar
I went to their website and it doesn't list an application for the HHR SS.
Old Nov 2, 2008 | 05:43 PM
  #36
hurst equipped's Avatar
what kind of boost are you seeing with this stage II tune?
Old Nov 2, 2008 | 06:42 PM
  #37
AaronSS's Avatar
20-22lbs. on average.
Old Nov 2, 2008 | 06:45 PM
  #38
405HP_Z06's Avatar
Keep in mind the most the PCM can currently control is an altitude corrected 22.5 psi.
Old Nov 3, 2008 | 07:24 AM
  #39
DrLoch's Avatar
Is that because of sensor?
D.
Old Nov 3, 2008 | 07:49 AM
  #40
rommer's Avatar
Nope, they use an 8 bit value to represent the manifold pressure which can only go to 255. Without going thru the math I've seen others use at HP Tuners that equals roughly 22.5lbs of boost.
This is suppose to change with the pending release of the GM stage kit but we shall see.
